Question about GE JSP69 Electric Kitchen Range
Replacing model jkp13gop3bg
What is the closest newest model to replace my old jkp13gop3bg without doing extensive change to my cabinet
2 Suggested Answers
SOURCE: I replace the glowbar on GE stove. However,
no. DOWN LOWD THE WIRING DIAGRAM FOR YOUR MODEL NUMBER BEFOR MOVING ON.
Posted on Nov 13, 2009
Need to oil Hunter Ceiling fan, Tyep G model 25539. Cannot find the place to insert oil. THANKS!!
There are only two places to lubricate a ceiling fan, the top and bottom of the armature that goes through the center of the motor. The blades in turn hook to this and rotate with it. The top of the armature, closest to the ceiling, is probably a little difficult to get at. The bottom of the armature is probably easier to get at. To do a complete job of lubricating both ends, the fan must be taken apart and cleaned of old lubricant which is then replaced with new. However, I have found that using a can of WD40 with the red extension nozzle is the best way to do it without taking the fan apart. Spray some WD40 at the lowest part of the armature supported by the motor housing. WD40 is better than oil because it penetrates better and it is less likely to cause a build up of dust and dirt that would cling to the oil.
Oct 13, 2010 | Hunter Dryers
The agitator seems to be stripped out - I need info on how to disassemble the agitator
Te newest ones are the easiest, a square hole can be unscrewed after removing the splash guard and belch dispenser.top Older models have a nut to remove. You must use an extension and socket for that. I have a nice video i found online: HERE
After I get the agitator out I set it on the floor and hold it down with my feet, I grab the top and yank it apart. I remove the old worn out agitation dogs and replace them with part number 80040 around $5 here. Line it all up and snap it back together without breaking the plastic locking tabs on the base of the agitator. While putting back the agitator take care not to make it come apart. This sounds hard but it is not. Anyone can do it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Nov 13, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I am getting static on the line - my end only - have had the phone lines checked - no problem. Phone is pretty old. When I answer it it makes a big screech before I can talk and then I have static.
sounds like you have a 206e card thats going bad. there are still alot of them out there and there not too hard to replace in the cabinet.To figure out which card to replace,match your extension number to the following: card 1 is extensions 10-15, card 2 is extiesions 16-21, card 3 is extensions 22-27, and card 4 is extensions 28-33. Make sure you power down the system if you remove or install any cards.
Nov 09, 2009 | AT&T Partner 18 Phone (315805B)
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
How do you change the spark plugs in my 95 buick century ?
Use a spark plug socket wrench, remove the plug wire, unscrew the old spark plug, screw in the new spark plug, and re-connect the plug wire. Do 1 at a time
Aug 03, 2009 | 1995 Buick Century
Older model Whirlpool oven 24
do you not know what a tape measure is or how to use one .we can not go shopping for you .
Feb 01, 2018 | Ovens
Blowing fuse on kx-t123211d
This is a good news/bad news solution. You must have had a LOT of years of trouble free service from the system. The bad news is the switching power supply is dead. It needs to be repaired...or you have a chance to find a 2 amp 24 volt DC power supply and insert it into the remote battery molex connector on the bottom right of the cabinet and it may work.
For everybody's benefit, the 123211d was made in like 1985-1994, so the first number in the serial number is the year and the second letter is the month A-L of manufacture. It could wirk for years, then one day, after a power failure or just turning it off, it would die. It would always be someting in the power supply and not the regulator card below it. We would take an old Key System power supply like an Elgin EAK-1 unit, and feed the battery backup port and it would run for years.
Of course, the best thing to do wiould be replace the cabinet and keep yuur old phones. If your 1232 has 32 Panasonic system phones, and all 12 lines, you're not going to be very happy, but here's a summary of what's available.
If your phones are 70xx or newer sets, you can reuse them in the newer Panasonic systems of TA, TAW, TD, or even the TDA/TDE with limitations. If you happen to have some of the 1232xx or 616xx phones, there may be some issues moving to the newest (current) systems.
The TA/TD 1232 starts at 8x16 and uses expansion cards that are hard to find to expand. You can usually find good deals on those old systems and they work well. I'd avoid a 123211d for the reasons above.
The TA-824 is 8 lines and 24 extensions. It's a current system and the base cabinet is 3x8, They are fairly inexpensive, but the expansion cards (2x8/3x8/0x8) can cost as much as the base system.
The TAW-848 and TDA-50 can have 8 or 12 lines (12 in the 50) and about 20-24 of the existing phones.
Anyway, this is the (long) fast answer to your question. If you have 8 or less lines and 24 or less phones, you can find a reasonalbe replacement and gain Caller-ID by changing out cabinets. If your system is larger, you may be looking at an expensive replacement.
Carl
Dec 23, 2008 | Panasonic Lands Phones
Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
Oct 20, 2008 | Seiko Kinetic watch
GE JSP69 Electric Kitchen Range Logo
238 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
