Question about Hitachi EDX-3280 LCD Projector
Reset filter timer
How to reset filter timer
    Novelist:
  • 149 Answers
Most projectors use a menu-driven system...enter the menu, look for the lamp reset menu--DON'T RESET THE LAMP! Usually the filter reset option is with or near the lamp reset option. And, most probably, you'll have to use the remote to access the menu options.Hope this helps. Btw, have you cleaned the filter recently?? I clean mine once a week! Projectors generate LOTS of heat...Any extra heat ages the internal components prematurely causing lamps to fail, LCD panels to break down, and circuit boards to display incorrect images. ---Rick
Posted on Sep 08, 2009
    Problem Solver:
  • 15 Answers
Replacing the filter should reset the timer. Make sure you used the correct replacement filter.
Posted on Sep 05, 2009
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
Do this projector has a filter that can be changed
1,Clean the filter
2,reset the filter timer: menu-setting-used hours of filter-reset the timer
Feb 10, 2014 | Toshiba TDP-T91A DLP Projector
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
What does the red light mean?
The red indicator light usually comes on when something needs attention. Most often it has to do with the lamp timer or the filter timer. The projector keeps track of how long it's been since you've changed the bulb or cleaned the filter(s). You can reset these timers in the menu. Be sure to clean the filter before you reset the timer. :)
Jan 17, 2010 | Optoma HD65 DLP Projector
Air Filter and reset the timer settings
go into the menu. it should be in the same menu as the lamp timer. as for cleaning the filter, use canned air.
May 18, 2009 | 3M MP 7750 Multimedia Projector
How do I reset the filter timer on the hitachi cp s210?
The reset function is in the options menu. Once you scroll through the menu locate the filter timer, forward to the timer locate reset, you then need to hold down the reset button on the bottom RH of the remote control.
May 07, 2009 | Hitachi CP-S210 Multimedia Projector
Not able to reset filter timer on ViewSonic
HI there
Scroll down to the filter timer in the Menu and hold down the right arrow button for a couple of seconds .
Apr 10, 2008 | ViewSonic PJ551 Multimedia Projector
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Mar 30, 2008 | Honeywell Electronic Programmable...
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
CLEAN FILTER/SET FILTER TIMER
go to menu, than select filter timer. press reset for 3 seconds, reset the filter timer.
Nov 21, 2007 | Hitachi Performa CP-RS55 Multimedia...
Hitachi EDX-3280 LCD Projector Logo
572 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Electro Med Services...
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
