Breaker keeps tripping from a/c unit - Heating & Cooling
  • 1,253 Answers
Does it trip immediately? Is the breaker a single pole or a double pole?
Posted on Sep 05, 2009
  • 32 Answers
That is usually a sign that either the compressor has shorted to ground or the fan motor is bad.
Therinnaiguy
  • 1420 Answers
SOURCE: breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Posted on Sep 12, 2007
TJBENGR
  • 121 Answers
SOURCE: my ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Posted on Apr 22, 2008
  • 700 Answers
SOURCE: AC tripping breaker.
Check its wiring connection. Could be loose connection, corrosion.Or the breaker is already retiring. If the breaker is fairly rated to the aircon unit. Also insect could be the culprit.
Posted on May 25, 2009
SOURCE: outside unit tripped the breaker. flip the breaker
either the start/run capacitor,or , fan motor is bad.-
Posted on Jul 06, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have 60 amp circuit breaker on my electrical a/c
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Posted on Dec 07, 2009
Testimonial: "Thank a lot this was very helpful"
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Titan SCR4 tankless water heater. Breaker on water heater itself keeps kicking. Not in breaker box. I have 2 double breakers, 50 amps each in box, no problem there. On the water heater there are 2...
Breaker trips when heat on wire exceeds amp rating, or when breaker is bad.
Most breaker are slow acting, and do not trip immediately.
Shorted elect could cause problem.
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 15, 2017 | Water Heaters
I have 2 15000 BTU A/C units run to a double pole 20 amp each breaker. The breaker keeps over heating and one side will trip. Should i separate the units on their own breaker? The units cool and run fine...
That would work, if for no other reason, to isolate which one may be drawing too much/more amperage. Keep in mind as well, after a breaker trips too many times, it usually will get weak and trip at lower amperage. If all is same, ( wiring from AC units) and units are cleaned regularily and no other internal problems such as weak, bad, capacitors etc, they should both draw same or close to same. If possible that someone has a multimeter with amp draw clamp, that would confirm where trouble is.
Aug 09, 2011 | Dometic Rooftop RV Air Conditioner
I keep reseting my 15 amp breaker daily. I even moved the unit.
No. The unit is only supposed to pull 9.1 amps. (wattage divided by voltage equals amps) Your unit has a short, or your breaker is bad. Turn on the unit, when it trips the breaker see if the breaker is hot, If so, thats an indication the breaker is bad.
Apr 11, 2010 | Danby DMW112 Microwave Oven
Keeps tripping the breaker
What size breaker?
as long as there are no other appliances or anything on the circuit a 15 amp breaker will do...if you have alot of other items on that same circuit you either need a larger breaker, or use a different circuit all together
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | Gold Medal 2656 Ultra Popcorn Maker
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
May 25, 2009 | Goldstar GW-HD5000 Window Air Conditioner
Circut breakers
Is it after it has ran for a while or tripping every time it comes on? If after it runs awhile check your wire tightness at the breaker and at the unit. Loose wiring will heat up a braker and trip it. Also check to see that the rating of the unit and the breaker are matched.
Jun 05, 2008 | LG L1004R Air Conditioner
Sep 11, 2007 | Heating & Cooling
Heating & Cooling Logo
322 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
