Question about Mtd Garden
Mower willnot turn over battery good- solenoid replaced
  • 138 Answers
Is the safety switch good in the seat and also check the safety switch on the brake pedal, if these check out then move onto to the ignition switch to make sure you are getting power out of the terminal marked s for starter. Sometimes new parts are bad also to rule out a defective solenoid and starter you can use a jumper wire from the pos post on the battery to the small termnal on the solenoid marked s for switch if the engine turns over then your problem is somewhere between the switch and the solenoid
Posted on Sep 07, 2009
My dixon ztr 3302 lawn mower will buzz but won't turn over. Battery is good, solenoid is good, changed out the sensor that sits on top of the mower deck, & wire to battery is hot but won't start
Check voltage on battery now and then after 8 hrs minimum charging at 2 amps. 13 volts good, 12.5 volts ok, less then that battery needs to be replaced.
Jun 15, 2016 | Garden
Where is the solenoid located on a briggs and stratton engine model number 282H07/0334
Mary Jo, solenoid is not normally on engine, follow the positive battery cable from battery to where it bolts to a small double terminal device(this is the solenoid) the other bolt has cable attached that goes to battery.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mower Starter Solenoid Replacement Craftsman Riding Lawn Mower Repair Part...
Replacing Solenoid on Craftsman Lawn Mower or Tractor
Mar 24, 2016 | Briggs & Stratton Garden
What should I try next? My mower will not start.
When you turn the key, do you have 12V art the Starter?
If you do, then tap the starter with a small hammer. If it cranks, then your Starter is failing
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Exmark mower will not turn over
check that the battery isn't dead. if it's good then check the fuse to the solenoid, then check the solenoid by jumping across the two terminals. if it cranks over by jumping the solenoid then it is either defective or you have a wiring issue from the key to the solenoid
Feb 15, 2013 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
My craftsman yt1000 23bhp, i have been jump leading my mower for around 6 months now, i started my mower last night no problem but got up this morning, turned the key and it just buzzed. so i origonally...
check the solenoid if you been jumping it off you could have burned it out and possibly the starter replace the solenoid first thats the cheap route and if that dosnt fix it check the starter if its buzzing or clicking its gone bad feel if it get hot if it does thats the bad sign to look for, replace solenoid, then starter thats my advise need more info messege me back for more, thanks, jamie
Dec 27, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
4x4 1990 f150 will not start
Does the truck turn over but won’t start? If so there is a fusible link running from the starter solenoid behind the battery.
Also if you get nothing when you turn the key could be the solenoid. Its easy enough to jump the solenoid and check . Check all the fusible links coming off the power side of the solenoid and replace as needed.
bobby18rg@hotmail.com
Jul 11, 2009 | 1990 Ford F150
Garden Logo
212 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
