Question about Kenmore 24032\24036 Top Load Washer
My Kenmore top loader starts to fill with water then stops.
My Kenmore top loader starts to fill with water but stops a short time after it starts. The only cycle that works is the spin cycle. We replaced the timer and that did not correct the problem. Any ideas?
  • 15,935 Answers
It appears your pressure switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Kenmore elite heavy duty king size top loader water will not stop running to the liquid detergent dispenser even when the tub starts filling Causing the machine to over flow
could be the water valve not closing properly, try unplugging the machine see if the water stops if not replace water valve. Also check pressure hose for cut and pin hole thx
Mar 01, 2014 | Washing Machines
I have a Kenmore Elite Oasis HE top loader washer; It will start but gives me an LF error.
this is a fault in the water valve control, "LF" means Long fill (fill time exceeeded), so u will need to have the sears guy out to sort this problem out. are the water valves on the wall turned on all the way?
Jul 15, 2009 | Kenmore Washing Machines
Ont stop filling with cold water
Hi. the pressure sensors in the water valve assembly appear to be damaged. you will need to replace the inlet water valve assembly in this case asap.
This is solenoid failuer. (basic water valve failure this case)
May 31, 2009 | Kenmore Washing Machines
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Wahser top loader
possibly cold water should be running into the tub at the same time as the cold to regulate the temp.by only having the hot on, it could possibly have timed out and while still being short of water
Jul 08, 2008 | Whirlpool LSB6200KQ Top Load Washer
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
