Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron kd28dl10u has moved house. retuned digital channels but itv and channel 4 are missing?
  • 1 more comment
  • golf274 Sep 05, 2009
    when i moved house the tv came too. when i retuned digital channels itv and channel 4 did not retune but all other freeview and radia stations did. both stations do tune in analogue mode (terrestrial stations only). the freeview box on my other tv is also missing these 2 stations.
    thanks
  • golf274 Sep 06, 2009
    many thanks.
    it does , however, appear that you are in usa and i am in england so i am unsure of the fix.i am in a block of flats with shared antennae.
  • david small
    david small May 11, 2010
    clarify please
    Problem Solver:
  • 18 Answers
I think i get the jist - you've moved, and now you're missing a couple channels. from what you're saying, i assume you are using a digital converter box, or have a digital ready tv. i personally have seen many problems since the digital change, specifically loss of channels. even though digital tv is supposed to be 'all that', and it is fine when it works, the quality and placement of your antenna is still critical. you are still receiving a signal on the same channel, only with digital, they have reduced the bandwidth. this action was not done with the consumer in mind, it was done to free up air space for other communicatiomns. try an amplified antenna [available at radio shack for about 20 dollars], and try different positions. if this doesn't work, you might try an outdoor antenna. with digital signals, if there is an obstruction between you and the transmission site, rather than getting a weak, snowy picture, or shadows, as you would back in the days of analog, your receiver will simply not receive the station
Posted on Sep 06, 2009
JVC LT22HD32J DIGITAL TV WONT HOLD CHANNELS AFTER RETUNE
It's October 2012 and I have a problem with my exact same model of JVC TV which has worked fine since i bought it in January. In fact it has worked the best out of the four that we have in the house working off the same aerial until 4 days ago. I tried retuneing and then the problem expanded to more channels. I tried to reset to factory options and then do a retune but lost all the channels. I have again reset and retuned and I'm back with channels that I can only tune into for between 4 and 15 seconds before the screen goes blank. None of the other televisions are affected. Digital UK website show no works to transmitters in our area and JVC are impossible to contact. Their site sends one around in circles in a most frustrating and unhelpful way. I will not be buying JVC again. Any help offered would be gratefully accepted!
Apr 14, 2012 | Televison & Video
Itv and ch4 channels have no signal on my digital
First check with some of your neighbours to find out if they have the same problem if you are using a communial aerial, if thiers are ok, try re-tuning the TV from "Auto tune" in the set-up menu, this will retune the entire TV & should pick up the missing channels.
Apr 14, 2010 | Televison & Video
Cannot get ITV or Channel 4 on newly aquired DTV, why is that?
The only thing I can think is happening is for some reason it's ignoring these stations. I suggest you try going to the factory settings for it. Then retune, it might clear the tunner's memory.
Feb 26, 2010 | Televison & Video
No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have lost channels 5,itv 3,and itv 4,and do not know how to retune my tv, all other channels appear to be alright slightly confused when i press the menu button and not know which links to follow?
All Freeview channels need re-tuned after 30th September.
To re-tune your Sony TV...
1.Press Menu button then go to settings...
2.Scroll down the menu icons until you get to 'Digital Set-up'
3.Press enter/centre key next to direction arrows
4. Select spanner icon and digital audio tuning.
5. You will then be asked if you want to start digital audio tuning.
6. Press enter/centre button....and thats it!.... TV will automatically re-tune.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi I have my Dad KD28DL10U tele as he has got a new one. He had satellite I dont. I cannot get itv or channel 4 on TV, also have lost 5 now that it needs to be retuned. Can you help me please. Alison
Auto program. rescan channels on your TV input. The TV has been scanned on the satellite it is set to pick up the channels that are avaliable on that system.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
We have a Thompson box in the lounge and until recently we had a Technix box in the conservatory. Both gave full coverage and good quality until a few weeks ago, when the Technix box gave very poor quality...
Can you try a non-working box in the Thompson box's location in the lounge? If you swap the boxes in the lounge and they both work normally then you must suspect that the cable supplying the conservatory must be the problem.
Feb 23, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
Loss of freeview channels
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
Feb 08, 2008 | Sony KDL-26U2000 26 in. LCD Television
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
310 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
