Question about GE DCSR483EA Electric Dryer
Drum not turning
When I go to turn on my dryer GE DVL223EBWW I can hear the timmer working and it sounds like it's getting power but nothing eles happens. The drum does not turn and nothing comes on. The drum turns but not freely both ways it has tension on it. And there is nothing in the dryer. Please Help!
  • 164 Answers
Have you recently lost a sock or a pair of drawers? Something mught be stuck in the impeller blower fan) attached to the motor. Very common problem
Posted on Dec 09, 2007
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
Dryer gets warm and tumbles but clothes do not dry. Is there a fan assembly that is not working?
Since this is an electric dryer, if it gets warm, that usually means that the heater is working. The drum tumbles so that tells you the motor is working. Which leaves a few things. Clogged exhaust vents could cause it, and even a dirty lint trap could effect it. But on your GE I would most suspect either the thermostat that is located in the dryer blower unit (http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Dryer-Parts/WE04X10028/0026/363/Model-DVL223EB6WW/0432/0151200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=G0407006&diagramPageId=00004&productTypeId=0151200&searchModelNumber=DVL223EB6WW&subCompDesc=Motor&brandDesc=GE&modelDesc=ELECTRIC-DRYER&blt=11) or the blower unit itself. Now remember that the blower is driven by the motor (which also turns your drum - so the thermostat becomes the most likely suspect. It is 1315 on the parts breakdown to give you an indication of where it is located.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DVL223EB6WW/0432/0151200/G0407006/00004
Aug 03, 2011 | GE DVL223EBWW Electric Dryer
My ge dvl223ebww electric dryer won't start,but does hum when the start switch is turned.what are the causes?
The top will come on off. Check the drum glides for wear
Once them glides wear out yall will be pinching the drum and causing motor stall.
With the top off you can sometimes push start and give it a little help to get it going and then listen out for signs of wear to the glides and bearing in the rear.
More HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 04, 2011 | GE DVL223EBWW Electric Dryer
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
MY DRYER IS NOT GETTING HOT IN THE INSIDE BUT THE OUTER BACK SIDE OF THE DRYER IS
Is your drum turning? Sounds like blower has stopped working. Or vent is plugged.
Lets check blower. Remove big exhaust hose. Now see if air is blowing out hard. DON'T put your hand in hole. If air is flowing blower is okay. So check the hose may need cleaned. Hopefully Hose is blocked.
Always unplug before removing any covers.
May 17, 2010 | GE DVL223EBWW Electric Dryer
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
Nov 19, 2009 | GE DVL223EBWW Electric Dryer
I HAVE A GE DRYER THAT WAS WORKING FINE ONE LOAD THEN STOPPED HEATING UP ON THE NEXT LOAS.IT TURNS FINE BUT NO HEAT
either your heating element,cycling heat switch,hi-limit switch,or thermistor are defective also check power input for 240 volts,if one leg 120 volts is missing it won't correctly
Oct 31, 2009 | GE DVL223EBWW Electric Dryer
GE #DVL226EB6WW
Here is a link to parts and drawing for your dryer: http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
If the drum won't move, likely culprit is the belt
Jun 08, 2008 | GE DVL223EBWW Electric Dryer
GE DCSR483EA Electric Dryer Logo
89 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
