Question about GE Washing Machines
I have a GE top loading 8 cycle heavy duty washer that will not agitate or spin. The tub fills and when it initiates the agitate I get the click and humm but no motor action. (also how do I find the specific model number)
  • 1 more comment
  • chuckmwright Sep 05, 2009
    The manual isn't available at the moment.. for a model there is a are these characters behind the right control panel, those characters are WWA8600 but when I do a model search online there are three to 4 alpha characters behind that..
    How do I make certain of that? couldn't it be the clutch or the motor, is there a way to be certain as to which one it is..
    Is there a specific part number for the clutch alone. or does that have to be replaced with the motor. there are two numbers on the machine WWA8600 and WA8607..
    Found the model .. now.. would a model wwa6600sblww have a one or two speed clutch assembly?
    President:
  • 2,187 Answers
To get the model n umber you need to look for the plate on the body of the unit. In some models it is located at the back. Check if the door switch is working properly (assuming your model has one). Inspect the actual switch if it there is some physical damage then test if it is actually working and if it is sending signal to the control unit using a tester. Inspect the washer while you have the panel removed. You may see loose linkages if that is the cause of the problem. Check if there is power to the motor. Using a tester you can measure voltages from the power to the control unit and to the motor to see where the voltage stops. There you should be able to identify should there be a bad electrical component. If all checks out OK you may have to remove the motor to have it tested without any load. It could be a weak motor or it may have gone bad. If the motor is OK then we are looking at an issue with the control unit or electrical components that needs further testing. Do not forget to check the wires for loose connection or bad wires that needs replacement.
Posted on Sep 06, 2009
  • 3,230 Answers
Well it seems like problem is in the Clutch assembly - it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it.
(the model number is provided in user manual or you can see it on washer backside)
post further comments if you need more help...
Good Luck!!
Thanks
Posted on Sep 05, 2009
  • Mukesh Kumar Sep 05, 2009
    Mostly problem occures in the clutch assembly.. so i'll suggest for it.
    No.. Clutch assembly is a seprat part.
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Washer will barley agitate or spin and make a
Try high speed only (cycles like cottons, heavy duty, etc. This happens when the low speed on the motor is not working. If high speed is working for you, the olny way to make the lower speeds work is to replace the motor.
Your part number is WH20X10019 and it's expensive...
Oct 20, 2009 | GE WBSR3140DW Top Load Washer
GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
May 30, 2009 | General Electric WHDSR209DWW Top Load...
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
GE 1996 top loader agitation but good spin cycle
check the motor, the timer,the water level indicator in side the machine on the basket it will have a tube with a little box attached to it. It may be clogged or malfunctioning.
Apr 27, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
