Question about Dryers
Front panel not rotating properly
I have an 18# super deluxe box fan with a revolving front panel. After only a couple months' operation, the front panel makes loud noises and does not rotate correctly.
    Sergeant:
  • 347 Answers
The gears for the revolving front panel is worn and slipping.
Posted on Sep 10, 2009
What services does Kia Sportage 2008 with 90000 need?
Here is recommended maintenance up to 10 1/2 yrs. If you follow through list, you should be able to tell by elimination what you may need. Here is the link - also list pasted below, here:
http://www.kia-forums.com/2g-2006-2010-rio-rio5/35574-maintenance-schedule.html
SUGGESTED Maintenance Schedule:
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
Jul 16, 2014 | Kia Sportage Cars & Trucks
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Fan Blade is hard to turn
Can try a little oil, if you can see the bushings on
the motor
Have to remove the fan, to get to the front one
That will work a couple months, then it's off the
the recycle center for the fan
Sep 12, 2013 | Lakewood HV 18-c Floor / Box Fan
Drum not revolving but belt OK
hello, there could be a couple possible faults first check the interlock on the door with power off check to see if it locks if ok then it may be the brushes on the motor you may hear a humming sound from the motor if you u still have trouble get back to me here is my email address superred@talktalk.net hope it helps
regards
shaun
Dec 26, 2010 | Hotpoint Aquarius WD640 Front Load...
How tight should the nut be on the front wheel bearings for a 2006 f250 two wheel drive.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Raise and safely support the vehicle.
  3. Support the front end.
  4. Remove the wheel cover, if equipped.
  5. Remove the grease cap.
    NOTE Check the wheel bearings for sufficient grease.
  6. Remove the cotter pin and retaining washer. Back off the spindle nut. Discard the cotter pin.
  7. Adjust the wheel bearings as follows:
    1. Tighten the spindle nut to 30 ft. lbs. (40 Nm) while rotating the brake disc clockwise to seat the wheel bearings.
    2. Back off the nut 2 full turns.
    3. While rotating the disc counterclockwise, tighten the nut to 17-24 ft. lbs. (23-34 Nm).
    4. Back off the spindle nut about 1 / 2 turn.
    5. Tighten the spindle nut to 17 inch lbs. (2 Nm).
  8. Install the retaining washer so the castellations are aligned with the cotter pin hole. Install a new cotter pin.
  9. Check the wheel and tire assembly for proper rotation, then install the grease cap. If the wheel still does not rotate properly, inspect and clean or replace the wheel bearings and cups.
  10. Install the wheel cover, if equipped.
  11. Lower the vehicle.
  12. Road test the vehicle and check for proper operation.
To check the wheel bearing adjustment, raise the front of the vehicle. Grasp the tire at the sides, and alternately push inward and pull outward on the tire. If any looseness is felt, adjust the front wheel bearings as follows.
  2. Remove the hub cap from the hub.
  3. Remove the cotter pin and the castellated nut.
  4. While rotating the wheel, tighten the adjusting nut to 21 ft. lbs. (28 Nm) to seat the bearings.
  5. Back off the adjusting nut until loose (120-180 degrees).
  6. While rotating the wheel, tighten the adjusting nut to 18 inch lbs. (2Nm). Torque required to rotate the hub should be 18 inch lbs. (2 Nm).
  7. Install the castellated nut and insert a new cotter pin.
  8. Install the hub cap
Mar 06, 2010 | 2006 Ford F-250 Super Duty
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
Overheating when we turn on the AC
I would replace the fan clutch. When you are sitting still or have reduced airflow across the condensor and radiator the fan clutch should compensate for that by pulling in more air. They are designed to free wheel when not needed for fuel savings, and will only fully engage when hot. They are deceptive when diagnosing, they will feel "tight", but can still not function properly. If your engine is relatively clean, look at the shaft and the front of the fan clutch. If there is any evidence of oil with dust collected on the shaft or the spring on the front of the clutch, just replace it. I was in the radiator business for years and I can say with absolute certainty that this is the main culprit with your symptoms
Jul 07, 2009 | Air King 20" Deluxe Box Fan with...
Speed indicators light up but no fan operation 18" floor fan.
Your fan speed control module is probably shorted and is damaged. Have it repaired by an electrician.
May 01, 2009 | Lakewood HV 18-c Floor / Box Fan
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
No heating
there is a relay on front panel this sends voltage to mwave needs to be replaced or dryjointed open front panel and check for little boxes on front panel those are relays
Jul 28, 2007 | Whirlpool MH6141XK Microwave Oven
Dryers Logo
37 people viewed this question
Top Dryers Experts
