Question about Philips GOGEAR SA6045 MP3 Player
It says file system error when i turn it on.
Tried resetting it but still the same. When it is connected to the computer it says disk is not formatted.
    President:
  • 392 Answers
Format the disk using windows...90% cases are solved using a format!!
Posted on Sep 05, 2009
Gigaware mp3 and when i turn it on, it says File System Error!!!
Get a small pin and insert it in the reset hole on the side or bottom of the device. It will format the disk, erase it and reset it to factory settings. You lose everything, but can reinstall it. First open up the drive and copy all songs to your disk or a flash drive, perform reset option then reinstall all music over.
Jun 07, 2010 | SanDisk Sansa e260 MP3 Player
No go
If you can get into BIOS check your boot order.  Set you HDD to first, then CD, then floppy, remove network if listed.
Oct 23, 2007 | Computers & Internet
Ave tried to use the recover disk 4 times now, and
If you reinstalled the Operating System and are still getting errors then it is a hardware issue.
From what you describe it sounds like your hard drive is failing. A failing hard drive will "lose" files out of nowhere and cause many "weird" errors because the lost files are usually system files needed for Windows.
Feb 11, 2010 | Toshiba Satellite M55-S3512 Notebook
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
On Armada M700 when I try to install windows XP a note tell me there is a disk controll error, soon it goes away, and when I insert the system diskettes on the 4th disk it will not go dfurther it says...
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:>
Once at the A:> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Oct 16, 2009 | Compaq Armada M700 Notebook
No operating system
Remove the disk-drive from your computer, and connect it as a "slave" drive on some other computer. See if you can read _any_ files from it, and burn those files to CD-R/DVD-R disks. On that other computer, run the "CHKDSK" utility to see if it can "repair" any file-system errors.
If not, use the "FORMAT" utility to "wipe" the hard-drive, and to see if the disk-drive is still in good condition.
Then, buy a new hard-drive, install it, re-install Windows, and restore your files from those CD-R/DVD-R backups.
Oct 10, 2009 | HP Pavilion ZE5200, ZE5200 CTO, ZE5207,...
System failure to boot
  1. Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
  2. Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
    - Floppy drive
    - CD drive
    - Hard drive
  3. Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Feb 03, 2009 | HP Compaq Presario V2000 Notebook
Windows Error Recovery - ''an unexpected I/O error occured''
Hi
This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again.
Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
Thank you
Rakesh
Dell Expert.
Jan 06, 2009 | Computers & Internet
Disk crash data recovery
its time for a data recovery operation. you'll want to find someone nearby, as this is a 50/50 effort at best.
got backup?
Feb 17, 2008 | Computers & Internet
Unplugged my armada m700
 - Floppy drive
 - CD drive
 - Hard drive
At the A:\> type fdisk <press enter>
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
All users
Oct 28, 2007 | Compaq Armada M700 Notebook
Philips GOGEAR SA6045 MP3 Player Logo
109 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
