Question about Frigidaire Dryers
I cant find the heating element on a stackable fridgerdaire dryer
FEX 831 CSO
  • 1,531 Answers
It is located in the cabinet of the dryer behind the drum the top needs to be removed and the front panel needs to be taken off then the drum removed
Posted on Sep 17, 2009
Kenmore stackable washer/dryer. Model 417.93802209. Dryer will run but won't heat. Flipped breaker. Suggestions?
Possible that the heating element has burnt out, or that the thermostat that controls the element is defective. If you have a low or warm setting try that also as it may use a different element? Good luck.
Jan 20, 2013 | Washing Machines
Fridgidaire high capacity stackable FEX831CSO/ washer/dryer no heat
If dryer tumbles but won't dry usually means the heating element has broke in two. It can also be a thermostat usually installed near outlet of blower assembly or a limit switch installed in element heater assembly.
Jun 16, 2012 | Washing Machines
Dryer runs but no heat. Stackable set, dryer on top.
More than likely the Thermistors are blown. They are located on the heating element canister inside the dryer, they are kinda oblong shape with two electrical connections. If you have a multimeter you can check for continuity on the thermistors and the heating element just be sure to disconnect one of the electrical connections on the thermistors and the heating element so you don't get a false meter reading, Thermistors can be purchased from most appliance repair businesses for around $30.appliancguru.jpg
Dec 10, 2010 | Frigidaire FGX831CS Top Load Stacked...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
GE stackable dryer not heating but it is running. I do have 240 volts at the outlet thank you
check the hi-limit and cycling switches on the element case along with the element itself for continuity,then if these are o.k. then check the thermal fuse on the vent pipe conduit inside the dryer near the vent connection as this is in line with the element and this opens up the element cant heat
Mar 27, 2010 | Dryers
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Need to replace the heating element in stackable Kenmore model 417.98702891
Go to www.repairclinic.com and enter 417.98702891. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of various parts.
Mar 11, 2017 | Kenmore Dryers
No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Apr 16, 2009 | Kenmore 88752 Top Load Stacked Washer /...
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
107 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
