Question about Video Game Consoles & Games
The USB part has broken off my GGE909 Game Elements Recoil PC controller. I want to know if I can use a different USB cord to attach to make the GGE909 usable again. Is it possible to fix?
  • Anonymous Mar 29, 2014
    so i have recently found my moms old game controller. Its pure white and gray on the back it says game elements GGE909 recoil. The problem is i dont really know how to set it up and what down loads or download i need.
    Problem Solver:
  • 5 Answers
The GGE909 uses a flat ribbon cable with eight wires, and has a spring loaded spool to store the cable.
Using a standard cable might work, but the new cable probably won't retract in the spool.
Posted on Jan 03, 2010
I haev a controller for my acer laptop. and it installed somthing when i put it in usb drive but its not working i have windows 7 is it compadable? its a GGE909 recoil controler
When you inserted the device into the USB port did it apply the generic driver? Have you rebooted the machine. Did it come with a installation disk? Is the game controller in Device Manager or in Control Panel, Devices or Printers?
Feb 25, 2013 | Computers & Internet
Ps3 controller charging failed
ok, either your charger for the ps3 is broken...or,it cant read(know)the cord is there. you may have dust or something clogged up. i know cause it happend to my ps2...i blew into the slot where the controller goes ( although u need to blow into the charger where u plug it in. if it doesent work... then u may need to either try a different usb plug or controller and see how it goes...OR take the controller and charger to a friends house if they have a ps3 and see if it works on theirs..if it vworks on theirs...then the thing where u plug the charger in at on the ps3 is probably broken or clogged up with dust
...if it doesent work on theirs than your usb plugs are brokn...
Jun 25, 2012 | Sony BD Remote Control for Playstation 3
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
I need software & manual for GGE909 rumble pad
Hi.
GGE909 rumble pad software (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 25, 2010 | Game Elements GGE900 (51691)
Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
Sep 21, 2009 | Garden
Recoil problem! I've just changed the start cord on my mower but now it won't recoil. The inner of the coil is attached the plastic wheel although the other(outer) end of the coil appears to be free. I'm...
You will probably find, that the spring inside, is not being stopped by the lug.
Usually, these do fail,..
Even when made from metal!
You will more than likely, have to replace the broken part.
Hope that helps you.
Jul 23, 2009 | Garden
I need a driver for my game elements gge909 gamepad for vista os
GGE909 can work under Vista and 7 without driver. hoever the "ESC" and "ENTER" key doesn't work. I wondered that the manufacture havn't write driver for Vista and 7.
Nov 16, 2008 | Video Game Consoles & Games
Broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Sep 09, 2008 | Garden
Video Game Consoles & Games Logo
427 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
