Question about Lexmark P4350 All-In-One InkJet Printer
Printer has frozen no button works won't switch off can't clear
I have a sharp ER-A450T it is frozen and I have followed all the trouble shooting things in the manual and nothing seems to work...please help
Hi Renee. The first thing to check with this model is whether it beeps when you press clear (The C button near the number 9 button). If it does not make a beep sound, you are right, it is frozen and the problem is usually either a faulty keyboard or printer (but you usually have an error code or dashes on the display if printer problem). Take it to be repaired.
If it does beep, it is not frozen and it is probably just waiting for you to finish something you started. Try pressing clear (C button near the number 9 button) in each mode and then press subtotal and then cash. So turn key to REG mode, press C SUBTOTAL CASH. Turn key to MGR mode, press C SUBTOTAL CASH and so on for each mode. If it shows an error message, please let me know which one and we can check further
May 09, 2017 | Retail Supplies
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
My print activity says something is being deleted but it won't delete
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted......
It will not show that message again.
Good Luck!!!!
Sep 26, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
Camera completely frozen. Lens protector open. Won' start with battery or AC power. Performed hard reste, no change.
have you tried removing battery and putting it back in? also what does "frozen" mean specifically? is it frozen in the menu with buttons not working or not powering up at all?
Aug 03, 2010 | HP Photosmart R827 Digital Camera
Out of ink - Printer controls frozen ??
Press and hold the resume button for 5 seconds.
Oct 22, 2009 | Canon PIXMA MX850 multifunction InkJet...
The "cover open" message appears on the display and will not clear. I have opened and closed. The printer seems frozen. How can this message be cleared?
look for a little button or hole that you can insert something into much like how the refridgerator light works, or the washing machine goes to spin with the lid open. i taped my button down and the error went away. can also do it on some models if you have a low ink message.
Jul 17, 2009 | Lexmark X3470 All-In-One InkJet Printer
Display frozen on "initiating scanner", start button illuminated
Turn off, hold down 6 button and keep holding while turn on. Wait for the three lights to stay on then hit the 3 button to scroll down to COLD RESEt and touch 6. It should restart itself and possible fix it.
Mar 09, 2009 | HP COLOUR LASERJET CM4730 F MFP Printer
Wii has frozen playing guitar hero
Hi. I got the same thing playing GH but without the nunchuck. Use the hand controller to re-sync. Press the sync button on the console FIRST and then the sync button on the hand controller SECOND.
I sat for hours trying to work it out - and it cleared the problem within seconds. Hope it works for you too.
Feb 20, 2009 | Nintendo Wii Console
Lexmark P4350 All-In-One InkJet Printer Logo
206 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
