Question about Fuji FinePix J10 Digital Camera
Lens is stuck will not pop out!
When I turn on the camera the lens will not pop out/open. I can hear the camera trying but nothing happens. Please help/ Any suggestions?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: lens stuck open
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 27, 2007
  • 11967 Answers
SOURCE: Fuji FinePix A345 Digital Camera lens is stuck, I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 17, 2009
Testimonial: "Thanks a lot, this is a F**king great solution, man you should post it a tip or something it's grat "
Stuck lens
Hi, 210 wide camera lens stuck is cause the spoil gear. This is commonly happen to physical damage camera.
Dec 26, 2013 | FUJIFILM Instax 210 Film Camera
Hi I am turning on my cannon ixy 700 and the lens is not opening up and i get an errror message on the screen saying E18 any help would be appreciated. Regards Leighton
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
The problem usually happens because dirt or sand get into the lens mechanism.
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
Jun 21, 2011 | Canon IXY Digital 700 Digital Camera
I have a EX-S600 Casio. When I turn it on the lens pops out, I get 3 audible beeps, hear some grinding and then the lens retracts and the camera shuts off, it all takes about about 6 to 7 seconds. I've...
If you hear a grinding then it's toast. Any issue with the mechanism would cost more to have repaired than replaced. This usually happens as a result of the lens being bumped while open or opened in a bag. Or, a contaminate such as sand inside the body of the camera.
Mar 28, 2011 | Casio Exilim EX-S600 Digital Camera
Lens stuck open on Lumix DSC-TZ5
This is a common problem when something goes wrong with the lens system.
This can be as a result of numerous problems.
Try to pull the lens as turning on and also gently twisting it in and out...just may make the lens go back on track.
Sep 21, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
The lens won't open/close and it beeps three times instead
the camera was last on the batteries were either extremely low, or they died and lens could have been kinda off track a little when it happened so it got stuck that way….Put in new batteries and If you lay the camera flat facing up at you and you look down and lens looks a little crooked….Push it slightly in the direction it needs to go to get back on track and when you hear the pop noise it’s fixed. Then when you turn the camera on if it stays on attempt to zoom in and out and the lens will then get back on track…and then TUrn it off and the lens should go back in
Jul 06, 2009 | Samsung Digimax S600 Digital Camera
Canon powershot a630 lens is stuck
My lens was stuck inside the camera and would not come out when I turned the camera on. I could hear a sound but nothing was happening with the lens. I used a dental pick (small sharp pointed object) to pull at the lens and it came out and seems to be working fine. Just tried it a couple of hours ago and It seems to be OK.
Dec 09, 2008 | Canon PowerShot A630 Digital Camera
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Camera lens stuck
We dropped our Samsung s730 (twice!) and got the lens jammed slightly sideways. I read a blog somewhere about this and just did what she said- If it is stuck out and obviously jammed sideways, push on the lens the way it should sit. I had to press really hard, but it snapped back into place and now works fine!
This WILL NOT work if: The lens retracts normally and goes back out normally, or it is not OBVIOUSLY stuck slightly askew. Sadly, with cameras this low in price about the only option is to replace it as repairs would cost more than a replacement.
In the future I plan on getting a squaretrade.com damage warranty on ALL my small 'droppable' electronics, it is pretty inexpensive (usually the same price as 'store brand' extended warranties that only cover defects).
Russell - Idaho USA
May 15, 2008 | Samsung Digimax S730 Digital Camera
Lens will not open
Good Day, if you hear gears trying to open the lens, then the lens assy is broken, no longer user serviceable. please call your nearest reliable shop(sony svc ctr) and ask for the lens assy price, if it fits your budget then you decide. For sure lens assy is defective. thanks
Aug 27, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Lens Error
Thus suggests a dirt entrapment. You will need a repair ship to look at it or go to Nikon website for this cameras model for Tech Support
May 17, 2007 | Nikon COOLPIX L2 Digital Camera
Fuji FinePix J10 Digital Camera Logo
77 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
