Question about Kenmore Washing Machines
Ho do you access lid switch
How do you access lid switch
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
To get to the lid switch on a Kenmore Top Load, you have to remove the cabinet.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Basically, you will remove two covers if your model has them, two screws, unolug the lid switch from the console and pull the cabinet forward.
Posted on Sep 23, 2009
2 Suggested Answers
BNewberry
  • 93 Answers
SOURCE: removing top cover to access switch
You have to pretty much use a putty knife to remove the front panel. Insert the putty knife into the edge of the front panel where it meets the top lid panel about and inch or two from the sides. One clip on each side. Push in the putty knife and give a little pull on the front panel repeat step for other side. That should get you into where you need to be.
Hope this helps you out. Feel free to ask any more questions about this if you run into anymore issues.
Posted on Mar 26, 2008
Ware is the stater Relay switch
starter relay switch i located under the engine ho compartment in the relay main fuse box just behiam the battry most ties the detailed diaogramm is on he lid cover if not on cvber in owners manual
Jan 03, 2011 | 1996 Jeep Grand Cherokee
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
LS error
The machine control detected that the lid switch is not functioning properly. Raise the top part of the washer to gain access to the lid switch.
Disconnect the machine from the power source. Gently pry the emblem from the front of the machine and remove the T20 torx screw hidden behind it. Slide the top of the washer forward and raise its front. Prop it up high enough to allow easy access to the lid switch.
The lid switch is activated by an actuator (part number 19119) mounted on a hinge. It will not work properly if the actuator is damaged.
Check the operation of the lid switch using a multimeter. Disconnect the lid switch wiring harness and connect the test leads of the multimeter (set to X1 or ohm) to the terminals of the lid switch and activate it. The multimeter should read zero ohms while the lid switch is activated and open when deactivated.
Replace the lid switch if it is broken or if it fails the test above. Remove the lid switch mounting screw and install the new lid switch. Reconnect the wiring harness and slide the top of the washer back into position. Reinstall the T20 torx screw and the emblem.
Feb 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do I acces the lid switch on my kenmore washer
The following link explains step-by-step how to access and/or replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Most lid switches are located under the right hand side of the top panel. Some, are located adjacent to either lid hinge. In any case, you still need to remove the washer exterior case to access it. The switch is held in place with a couple of mounting screws with a ground wire attached. This is a very simple repair, but if you experience any difficutlies please let me know. I hop this helps you.
Nov 27, 2009 | Kenmore 24032\24036 Top Load Washer
The washer does not drain the water or spin. Does the drain work when the spin cycle starts?
pull end caps from both ends of back splash remove 2 screws flip control panel back...remove 2 clips(use screw driver to pry up)...disconnect wire plug lift lid put hands in opening pull the case to you and up to remove entire case...remove 2 screws that hold lid switch install new switch...(don't forget to plug the wire plug back in...ho ho
Aug 26, 2009 | Kenmore 23822 Top Load Washer
Whirlpool Thin Twin Lid Switch and Return Pump access
where the washer and dryer attach just above washer lid there should be screws to rmove cover between units yours may have clips instead of screws that need to be removed to remove lid and top on rear edge of top there is a plug that hooks lid switch just watch when reinstalling top to be sure it reconnects..sorry for mix up those units had 2 different layouts over the years and without an image hard to tell which one you had
Jun 12, 2008 | Washing Machines
Lid switch won't unlock at end of cycle
Yes! The lid/door WILL UNLOCK after a 45 to 60 second delay, This is for YOUR SAFETY this action prevents you from opening the lid/door to a coasting washbasket. You CAN or WILL be seriously injured if you insert your hand(s) into the machine before the washbasket stops!
Mar 26, 2008 | Frigidaire FWS833A Top Load Washer
Removing top cover to access switch
Mar 22, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
66 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
