cd/dvd cleaner may or may not help. I've fixed a few 360 with the same error by doing the following:
Note this will void warranty if you have any.
Take apart the 360 and remove the dvd, open the dvd drive exposing the laser.
take a cup of water and bring it to a boil and let it settle for a minute
dip a q tip in the boiled water wipe off any excess and gently wipe down the laser lense. (Ive tried alcohol to clean the lasers but this gives me better results)
close the drive back up and test it before you close the whole unit up.
If you still get the error you may have to adjust the laser lens potentiometer to give it a bit more power.
for error 74 how do i fix it it has been doing it alot and i need help with it it is only showing...
(More)
for error 74 how do i fix it it has been doing it alot and i need help with it it is only showing one ring of death and i dont know what the matter it is with it
I have an original xbox and it all of a sudden shuts off with no warning and then I turn it back on...
(More)
I have an original xbox and it all of a sudden shuts off with no warning and then I turn it back on and it brings the xbox menu up and shuts off again. I timed it and I get allmost an hour of play. This even happens with an extra fan blowing on it.
