Question about Samsung HLP4663W 46" Rear Projection HDTV
Erratic operation,intremittent failure
After the tv is on for a shot time the tv makes a loe tonr sire like noise and the picture goes out. all of the led indicators are on at the same time
    Genius:
  • 1,694 Answers
Bad color wheel......need lamp code # to get correct # for wheel
Let me know..............T.
Posted on Dec 17, 2007
'94 Gmc Sonoma 4.3L Starts loosing Power and making weird Rattle Noise when reaching operating temperature. Also water tank looks like there is a bit oil in it. Could it be the cylinder head gasket?
Oil in the coolant is usually an intake manifold gasket problem on these engines. If a head gasket failure the engine will normally overheat and give erratic temp guage readings. Make sure the oil level is full. Is the rattle noise coming from the engine? Some times the exhaust (converter) will fail and the catylist will seperate causing a rattle noise from the exhaust and plug it up giving a no power situation
May 23, 2015 | 1994 GMC Sonoma
My lg tv has sound but no picture
Sounds like power supply is failing
Dec 24, 2017 | LG 42LC2D 42 in. LCD HDTV
The picture is breaking up
Check all inputs sire harshness for firm. If there is any loose connections to these, the fault you reports here can occur.
Feb 05, 2013 | Sharp LC37SB24U 37 in. LCD TV
I have sound, but no picture. A bright horizontal line appears across the TV screen, again, no picture ?
Hi
Thanks for using FixYa. Heat is the number one enemy of electronics, and these sets operate hot. This problem is caused by the power supply being overloaded. This is often caused by failed convergence ICs. The safety circuitry shuts the TV set down when it detects a problem. Some parts for this TV will be hard to impossible to find. This model of TV has over 3,000 parts which include millions of transistors inside the integrated circuits. Over time the capacitors will change value, leak and become defective. Resistors will change value and burn. This will cause other components to become defective. This can has a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 29, 2009 | Panasonic Televison & Video
My Panasonic LCD had a little pop sound and we completely lost our picture. I just bought a new lamp TY-LA1000 and I turn on the TV and the switch color goes from flashing Green to flashing yellow 2 blinks...
You probably need a new ballast.It is a high failure part.If you listen at the back of the set you can hear the ballast make a short buzzing noise every time it tries to light the lamp.If you don't hear this then your ballast is probably bad.
Dec 07, 2009 | Panasonic PT-52LCX65 44" HDTV
Samsung HL-P5063W makes a whining sound and then goes off
The most common failure in the DLP that makes a whining sound would be the color wheel. They cost about $135 + labor because I wouldn't advise changing it by yourself.
Aug 02, 2009 | Samsung DLP HL-P5663W 56" TV
I just heard a loud pop and my picture went to out
the service manual is available in the web site andrewselectronics for sell.
there is a chance to inspect the lamp and see if is damage (normal failure for this popping noise) consult you user's manual ...How to replace the lamp. as i said inspect it and replace it as needed, use original lamp. Toshiba
Feb 23, 2009 | Toshiba 62HM95 62" HDTV
Picture tube not working
Please provide more info.
1. Does the TV stay on, if so,
2. Is the LED flashing, how many times stop same number of times again
3. If TV goes to stanby, count the flashing LED.
4. If LED comes on goes off , at firsdt switch on. does it make a thumping noise.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Motor runs continuously
the magnification motor cannot find its home position at this time, causing a erratic operation, soon enough the motor will wear up and would cause you more damaged. you need to take this to repair center and either clean the sensor or replace the home positioning sensor
cheers
Aug 12, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Samsung HLP4663W 46" Rear Projection HDTV Logo
24 people viewed this question
Jerry Greenberg
Jerry Greenberg
