Question about Kenmore Washing Machines
Keep receiving a F06 error. Running machine on 50 cycles. Is this the cause of the problem? If so, are there any motors for this machine which are 50 cycles?
  • redi_mix Sep 05, 2009
    please send me the details of my chart.I need to get from it certain links which were provided
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
F06 error code
Hi Bunny:
F06 code will indicate a drive motor tachometer error; means the control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes. Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 14, 2011 | Frigidaire GLTF2070DS Front Load Washer
My duet does not wash it keeps coming a code F06, what could it be
F06 error code is Drive Tach Motor Error.
The cause of this is the motor control (MCU) not communicating with the control board. Try unplugging the unit for 30 seconds and if this does not solve the problem replace the MCU. This is located behind the panel under the door screwed to the floor of the unit near the motor.
Click HERE to order the replacement MCU
Hope helps.
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am greeting a flashing code of F06 as in goes into spin cycle and it stops running.
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Apr 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the problem when I get F06
F/06 says: Drive Motor Tachometer Error. Check Wire Harness connections between the Drive Motor/Tachometer and Motor Control Unit and between the Motor Control Unit and the Central Control Unit. Check the Drive Motor, Motor Control Unit, and Wire Harness. Hope this machine is still under warranty! Good Luck!
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F06 Error Code
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Sep 11, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite 3 that flashes f06
"F06" is a Motor Speed error code. This could indicate a problem with the drive motor, motor control unit (MCU), interconnecting wiring, or the tachometer (part of the MCU). The following link explains:
I would begin by checking all the wiring and connector plugs between the MCU and drive motor. Vibration from the washer can cause the connectors to come loose. Also check them for any signs of corrosion that may be causing poor contact.
Measure the motor windings to see if they are still within specs. Bad motor windings could generate the error code as well.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Jul 08, 2009 | Kenmore Elite 45986 Front Load Washer
Flashing code F-6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Apr 12, 2009 | Whirlpool GHW9300 Duet Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
