Question about BenQ FP731 17" LCD Monitor
No audio I just hooked up this monitor and somehow lost sound, cant listen to music, am I missing a cable or something. I only had the power and the 1 cable for the monitor
  • redlessi Dec 08, 2007
    i hooked up the
    BenQ FP 731 17" LCD Color Monitor
    Champion:
  • 220 Answers
No way monitor is causing the problem.Could be driver related issue.
Samir
Posted on Feb 27, 2008
No audio
I had to get speaker that came with a black box that hooks up to my monitor and CPU so I can stream movies and listen to tunes. The name on the box is: Altec Lansing. About $40.00
It's a powered audio system.
Mar 31, 2013 | HP Intel Pentium Dual Core Desktop...
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Mar 08, 2011 | Audio Players & Recorders
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
When i am listening to music i notice that the music starts to get quieter and after about 1 hour or so it goes silent if i just leave it i cant see the slider moving when i watch it but when i leave it...
Look for a fade or cross fade function.
Use the "help" feature of the TB software to research things under these two names. Somehow one of these might have got set to a long time period rather than never.
Dec 30, 2009 | Voyetra Turtle Beach Santa Cruz Sound Card
No sound listening to music and audio stopped
Tape monitor is it on? Muting? How old is this unit? Does speaker relay click on secoinds after unit powers on? If relay does not click probably output problem. Try disconnecting speaker wires to see if relay will click. If it does click the suspect bad wire or speaker if not bad amp. The first step to diag is to diconnect everything and simplify the citems needed to get sound. 1 Known good signal source and cable, Minimum affects, check speaker switch, Known good wire and 1 speaker to front l or r terminal. iIf still know sound seek serv.
Aug 29, 2009 | Teac AG-V8060 Receiver
Built in speakers
I'd guess there is a jack socket 'audio in' somewhere on the montitor, probably on the back. (Don't confuse it with the headphone socket, which usually looks the same.) Connect it with a 3,5" stereo jack-jack cable to your PC's audio output.
Mar 20, 2009 | Polyview S17E 17" LCD Flat Panel Monitor
Problems with monitor
Are sure you plug into the right socket jack.
Try plugging different socket and listen.
Jan 19, 2008 | Star Logic 17" LCD Monitor
Monitor brand
hi,
Try to check the small cable at the back of your monitor if it is connected at the back of your pc, basically the audio port at the back of your pc have 3 same holes mostly the middle hole is the audio port, if you have more than 3 holes try guessing while your playin music.make sure the jack fits, if the sound appear it means thats the right port for that.
Dec 07, 2007 | Computers & Internet
BenQ FP731 17" LCD Monitor Logo
78 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
