Question about Kodak 5500 ALL-IN-ONE PRINTER
I have purchased a Kodak ESP5 printer and it wont scan
It will print a photo and a document but everytime i press for scan nothing happens, but the printer says its scanning.
I have a Kodak ESP5 all in one printer. At first
Call 1800 421 6699
Printhead needs to be replaced.
It free of charge replacment
Feb 13, 2010 | Kodak ESP 5 Printer
Scanner doesn't work
You need to have the Home center software installed on your computer.The home center software has scanning drivers of the printer.If the printer says scanning,may be the drivers on computer are not taking commands from printer. Kindly mention the name of printer.Kodak has recently launched a new version of software 4.2 . It usually solves the issues relating to scanning and printing from computers.Download the latest version of software from www.kodak.com/go/downloads.
Sep 26, 2009 | Kodak ESP 5 Printer
I recently purchased a Kodak esp5 all in one. I
Make sure that the printer is connected to your computer and you have the home center software installed on your system. Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Sep 05, 2009 | Kodak ESP 5 Printer
When I print, it says spooling
Go to Control Panel, Printers and Faxes, Cancel any pending document on your Kodak Printer, then delete all kodak icons.
Turn off the printer, Unplug and Replug the USB cable, then turn on the printer. If nothing happens..
Second options: Click Start then select Run Type the word "net stop spooler" then "net start spooler" Then unplug and replug the printer while its on.
Josh
Aug 18, 2009 | Kodak ESP 5 Printer
Just purchased esp printer, does this have to be
You do not need to connect it to computer to print photos. the printer, place any document on the scanner glass and put papers in the document tray and press copy. if the printer does not work, Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.The usb cable does not comes with the printer and you need to purchase it additionally
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When i press scan the display shows 'scanning' nothing happens - the printer works and is connected... kodak esp 5
connect ur printer with ur computer thru a usb cable and then try to scan a document from computer using home center software. u will be able to scan the document or picture.
Jul 28, 2009 | Kodak ESP 5 Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My Kodak ESP5 won't scan...
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. may be problem with scanner drivers. new software will fix up your issue. Enjoy.
Apr 16, 2009 | Kodak ESP 5 Printer
Kodak 5500 ALL-IN-ONE PRINTER Logo
47 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
