Question about Yamaha Audio Shelf Systems
Yamaha Electone HS6 Organ
Seems like some sort of power problem, nothing lights up, but there's a clicj after a few seconds. Any idea where/how I can get it fixed?
0 characters
1 Points
Hitachi axm76e
This is probably the power supply. In most cases there is a bad capacitor in there. You can have a new power supply put in or have someone fix it with component level trouble shooting .
Nov 18, 2013 | Audio Shelf Systems
No power jbl speaker
that was mean has shorted line, check for shorted amplifier ic.that was mounted in big heat sink.
Aug 16, 2012 | Audio Shelf Systems
Just purchased the RT2911 this afternoon at a local Wal Mart.. Got it home, out of the box, on a shelf, distributed the speakers accordingly, plugged the unit in. I powered on the receiver and immediately...
Did you try reversing the speaker cables in the back of the unit? I mean making sure the ground wire ( the wire with a black stripe on it ) is in the right connector.
Feb 07, 2012 | RCA Audio Shelf Systems
Philips MCW770/37 stereo will not power on any longer.
Hi ,
This is just a suggestion. Check your speaker wires at the back and at the speakers. A shorted speaker wire will cause a tripped breaker.
May 19, 2010 | Philips MCW770 CD Shelf System
Antenna Wire Missing.
a length of wire similar to the original should work. The end bit may have been an F-connector. Just plug the wire into the middle of the connector on the back or the receiver. Adjust the position of the wire till you get a good signal.
Apr 20, 2010 | JVC UX-GP5 Micro Stereo Audio System Shelf...
BeoSound 9000: Similar problem, AND no AM/FM/Aux either
sorry nothing straightforward springs to mind.A dealer repair seems the only solution.
Sep 16, 2009 | Bang and Olufsen Audio Shelf Systems
Lights flash on the unit at night making it hard to sleep!
The power button does nothing in relation to this!!! Press the x-bass/demo button at the bottom of the remote. That should fix the blinking lights! :)
Feb 26, 2009 | Sharp XL-DK225 Shelf System
Blinking Red Light - Nothing Works
Call Sony, give them serial number (rear of unit) provide descripton of problem and failure to operate after powering off and they will issue a case number and give you an address in Lubock TX to send the unit. Send the unit, with the case number showing on the shipping label, include a proof of purchase, description of problem, return address. Also if you like me, have CD's in the changer make sure you note that during the telephone call with Sony and again on the description of problem. Very fast phone call.
Oct 20, 2008 | Sony CMT-CPX22 CD Shelf System
Radio does not work
If the unit is only a few months old, returnit for warranty repair or exchange. A power fail should not effect it. Try unplugging it for a few hours to force a system reset. If that fails to resolve the problem, have it serviced under warranty.
Jun 03, 2008 | Audio Shelf Systems
No sound
i have got the same sterio with the same problem, technics are usualy the best around but this sterio is an absolute waste of £500 my solution is to just wire a different amp up to the old one
Jan 08, 2007 | Technics SCEH790 CD Shelf System
Audio Shelf Systems Logo
174 people viewed this question
Top Yamaha Audio Shelf Systems Experts
Are you a Yamaha Audio Shelf System Expert? Answer questions, earn points and help others
