Question about Sony KP-53XBR45 53" Rear Projection Television
Sony kp-53xbr45 is bowed and looks 3d convergance moves all directions but wont fix bow
  • 178 Answers
You have a failure in your tv. This is a common failure with many big screen tv's. The convergence driver ic's have failed, they are located on the "D" board in your set. if you want to repair this yourself you need to be aware of the dangers of working inside a televison, even with the tv unplugged from the wall it will still cary voltages that are very dangerous.
There are two approches to the repair that the Technican may use, One approch is to replace the whole "D" board this is the more costly approch, the other approch to the repair is to replace the STK392 ic's and any blowen pic fuses. This repair from a service tech will cost around $300.00 to fix. If you want explisit instructions on how to repair this problem post back and i can get them for you.
Posted on Sep 05, 2009
Testimonial: "Thank you that is better than a new tv"
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Looks like the center of the screen is smaller.It bowes in on the top and bottom.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Sony KP-53XBR45 53" Rear Projection...
Problems with Sony KP-51WS510 Rear Projection HDTV-Ready
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Apr 09, 2009 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-65WS510 Convergence Problem
Screen looks 3D
>>>Solution<<<<
Jan 17, 2009 | Sony KP-65WS510 65" Rear Projection...
Convergence problem?
Screen looks 3D
>>>Solution<<<<
Jan 14, 2009 | Sony KP-65WS510 65" Rear Projection...
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
Screen looks 3D
>>>Solution<<<<
Dec 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-WS500 bowed picture and colors seperated and out of focus
  • Screen looks 3D
Nov 22, 2008 | Sony KP-51WS500 51" Rear Projection...
I have a pic problem is it fixable
If the picture is bowing in on the sides, this is called a pincushion problem. Please confirm that your model is KP-53XBR45 and I'll look up the probable defective parts.
Dan
Aug 26, 2008 | Sony KP-53XBR45 53" Rear Projection...
Red bowed lines
  • Screen looks 3D
Aug 06, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
306 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
