Question about Sony Ericsson K800i Cellular Phone
Ear speaker not working and no dial tone when ringing out
Bell Studio 4500 DECT phone with answering machine: just out of warranty, this phone does everything properly up to entering a number, then dialling, BUT not producing a ringing-tone or getting through to...
I gather you have the setting for tone and pulse set to tone? Also are you aware the ringing tone is generated by the phone company? When you dial a number and it connects, the phone provider sends the ring signal to the dial phone and the ringing signal to the dialing phone. Do you get a dial tone before dialing?
Jul 26, 2017 | Lands Phones
Nokia 5800 XpressMusic dial tone not coming and auto call on
My suggestion is that you upgrade your software and firmware. A good place to start is the Nokia Download Center. CLICK HERE
Jun 17, 2012 | Nokia 5800 XpressMusic Smartphone
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
No dial tone?
you need to get a new ear speaker or the to pins on the one you have are not conocting properly
Oct 17, 2008 | Samsung SGH-D600 Cellular Phone
Service was connected on Saturday 10/11, telephone rings in your ear when phone number is dialed, telephone not ringing inside the home.
If the caller hears ringing after dialing the home but the not ring inside home. That means the number is active but the wiring inside home is faulty/ not properly connected. A phone rings /or works of a basic system. Two wires usually red/green as primary. If either one is broken or improperly connected the phone inside will not ring. That doesn't indicate a short. If it was a short the caller would not hear ringing at all. So the first thing you must do is the track the cause. Make sure home phone is plugged securely into phonejack. Still no dial tone check all other jacks inside home. If still no dial tone. Contact your service provider. They will need to send a technician to check the Demarcation point. Which simply means the connection point where the service provider wires , meets the customers house wires. They just need to verify this connection
Oct 13, 2008 | Lands Phones
My phone will not dial a call. I get a dial tone,but it won't work. I also can not get it to ring the different ring tones or do the hands free speaker phone.
You have got to be kidding. I pay $25.00 for a phone that does not work and you have the ordasity to tell me that if I pay you an additional $9.95 you will e-mail me with a possible solution to my problem. If I do not here from you within 24 hours, I am going to report this to the Better Business Bureau and my local Consumer Advocate News station!
Mar 02, 2008 | Innovage LCD Touch Panel Phone
Phone rings but when answered the caller can not be heard.
Your ear speaker is bad. You may need to replace it.. This one made by HTC. You can check on Ebay for replacement part. Other issue could be is the hardware part of the ear speaker may be broken or defected will cause loosing contact with the main circuit or you can say it is short. Only solution is open the phone and check for that area to see for any defective.
Apr 21, 2007 | O2 Xda IIs Pocket PC
Sony Ericsson K800i Cellular Phone Logo
269 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
