Question about Philips 42PF7320A 42 in. Plasma HDTV
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
    President:
  • 1,077 Answers
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Posted on Sep 06, 2009
  • William McNeel
    William McNeel Feb 23, 2011
    Possible cap on your power suppy or either its the panel. I had the same issue and it ended up being a bad panel and the only way to replace those would be to pick up the exact same tv and model and swap boards to make a good tv.
I have a Phillips 42in plasma 42PF7321D/37 when you turn tv on green light lights up you have sound and picture flickers a few times and then picture is fine and looks great. Noticed menus are hard to see...
I would certainly say the problem is in your power supply. Chances are real good that two capacitors are bad! You will have to remove the back cover...this is tedious and requires patience. You will be concerned with the board on the left side. You will have to remove the screws on the power board to lift it and see the top of this board. You should see at least one bulged capacitor. Replace, and you can bet the other next to it is bad. And another note..there may be a small cap at about 16volts at 10Mf that needs attention. These are clues and should help with repairs! Thanks for asking.
Aug 21, 2010 | Philips 42FD9954 42 in. Plasma HDTV
I have a 42PF7321D/37. power lite blinks 4 times and repeats. no picture
You need to replace the caps on the PSB-Power supply board
Best regards and Semper Fi
Aug 03, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
Apr 26, 2010 | Philips Televison & Video
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
Phillips ssb
It is pretty much a plug and play. It is more time consuming than any degree of difficulty.
You must make a strong mental note of where each screw goes.
Simply disconnect the Molex connectors and the screws on the Signal Board; you're pretty much reverse the process. No cutting or soldering is required!
Dec 08, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Power problem for phillips 42 plasma 42pf7321d/37
That blink don't mean nothing. Measurements need to be made. Don't just buy the board troble shooting would need to be done to see witch board is bad. Also look on the fron of the set and see how many time the led flashes. That wher your error code comes from..
Philips 42PF7320A 42 in. Plasma HDTV Logo
1,259 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
