Question about Gestetner DSc224 Copier
How to use gestetner dsc224 as Mac OS X printer
I have a gestetner dsc224 which I want to use as a printer from my Mac running 10.5.8.
I've done the usual google searching and found software to download from http://support.ricoh.com/html_g/model/c24_32/310en.htm but it doesn't seem to help...
I've installed the Mac OS X v10.5 or later PPD Installer (Ver1.4.0) and Printer Utility for Mac (Ver.2.2b9.01d15) but I still have problems. IPP refuses to "unpause" the printer & does nothing. I've managed to get the printer to print when set up as LPD but it just prints pages such as:
%!PS-Adobe-3.0
%APL_DSC_Encoding: UTF88
%APLProducer: (Version 10.5.8 (Build 9L30
etc....
followed by gobbledegook! I understand this is some Postscript issue.
When I add the printer should I choose LPD or IPP? (AppleTalk cannot find a "zone" so is greyed out - should I be using it, if so how?)
I have a modem/router, Power Mac & the printer all with fixed IP addresses on the network.
What a headache!
  • mattviolin Sep 24, 2009
    I have now bought & installed the Postscript option & it works a treat! Thanks again...
    President:
  • 1,126 Answers
You need a PostScript (PS3) DIMM for the DSC224 so it will understand what the Mac is saying to it. Obviously the machine has network print option installed, otherwise there would be no response at all. The PS3 DIMM installs on the print controller board. If I remember correctly, (looking from the rear of machine), left side behind outer cabinetry......a bit deeper, then behind metal RFI shield,,,the proper slot is labeled on controller pcb....if not labeled, it will be the only slot open for this sized DIMM. I must admit, it has been 3 or 4 years since I've assembled one of these models. Hope this helps.
Posted on Sep 06, 2009
Testimonial: "Very helpful advice, thanks very much!"
Yah basically had the same problem u can add non-post script support to mac though
PCL XL printer by the lovely opensource photoshop folks
http://gimp-print.sourceforge.net/MacOSX.php
You can detect if thats the problem by following these excellent instructions
http://www.linuxfoundation.org/collaborate/workgroups/openprinting/database/ricohfaq#How_Do_I_Determine_if_my_Printer_Supports_Postscript_.2F_PCL_XL_.2F_PCL5_.3F
Anthony Mckale
http://zapper.hodgers.com
Posted on May 25, 2010
Dsc224 ploblem sc142
Error Detection White Balance
The White Balance can not be resolved glass or optical section
within the target at the Spotted
automatic gain control. Card SBU defective
Map BICU defective
Exposure lamp defective
• Cruise the lamp defective
May 31, 2011 | Gestetner DSc224 Copier
I have aficio Dsc224 and i used wrong towner color i used aficio C1224 by mistake and the machine not work propebly ..
The toner for Ricoh 1224C and the Gestetner Dsc224 are the same. Here is a link to show you that the toners are the same for this series.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.precisionroller.com/search.php?q=1224C+toner
Dec 21, 2010 | Gestetner DSc224 Copier
I bought a Gestetner Aficio DSc224 multifunction copier, but the screen display functions is in French. How can I change it to English, since i do not understand French
press the system key/ (123) button have a look through the menus its in there somewhere
i have a feeling that it is on the 1st screen after u press the system key in top right hand corner
Nov 19, 2010 | Gestetner DSc224 Copier
Jsc570 code
This is a common error for the dev fam motor if you hav etaken th back off and done any repairs the connector is loose or the fan may be clogged up with toner and cant turn.. try cleaning with brush or vac..hope this helped A
Jun 23, 2010 | Gestetner DSc224 Copier
Postscript Option (PS/3 DIMM) for a Gestetner DSc224
either from a local dealer or you try and google it or Ebay
Sep 15, 2009 | Gestetner DSc224 Copier
Gestetner DSC224 Scanning and Fax Issues
scanrouter? disable delivery server from scanner menu
Jan 22, 2009 | Gestetner DSc224 Copier
Gestetner 2850
check the charge corona , if you open the front cover it is a little brown plastic block that has got one screw holding it and one wire connecting in the pcu , take the plug out and pull out the corona unit and check if the wire inside the silver frames is still there , look care fully it is as thin as a hair
Aug 14, 2008 | Gestetner DSc224 Copier
675 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
