Question about Homelite Mighty Lite Lawn Trimmer
The head of my stihl 45 c weedeater keeps falling off
When in use the head falls off and the drive wire comes out
Does a stihl weedeaters have primary & secondary windings in their coils ?
which model.?? I have all the parts manuals so will gladly help with a little more info
Apr 22, 2016 | Stihl Garden
The head keeps falling off my weedeater brand weed eater
Add a split washer. Turn it tight enough to compress the split into a flat washer. The spring tension of the washer will hold it on. If not, you will need to add some Loctite.
Apr 17, 2014 | Homelite Mighty Lite Lawn Trimmer
Stihl fs44 weedeater wont fire
Do you have compression, a good spark and is fuel going into the cylinder.? Working on a solution.
Jul 27, 2012 | Stihl Garden
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
The drive belt keeps coming off even after i replace the belt. the drive pulley on the rear of mower has a little wobble in it, is this a problem
You answered your own question. The source of the wobble may also be a worn bearing or bushing supporting the shaft the pulley is mounted on. Be certain that you are installing the belt over the proper path of pulley's I know that My personal Mower WEEDEATER 42" can have the belt installed wrong it works but will fall off in heavy grass.
Apr 14, 2011 | Craftsman Garden
How to get the head off of a Stihl weedeater. Model FS 45
There is a hole beside the angle gearbox, stick an awl or small screwdriver into it & turn the head until it 'locks'. Then rotate the head clockwise until it comes off.
Jul 29, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Stihl FS 45 throttle problem
its a self fix just get a new one it will come complete
Jul 24, 2009 | Garden
What is the gas/oil mixture ratio for the featherlite gas weedeater?
its a 40:1 ratio. remember to never tap the tap-n-go too hard or it will bend the shaft, and make the head hot to the touch, and eventually will melt the inside. And always keep fuel stabilizer in the gas, because if you dont, especially in winter and fall, it will clog the carb so you have to keep pumping the throttle to keep it running and you have to run it on half choke all the time
good luck!
,devin
Apr 25, 2009 | Poulan Featherlite Gas Blower, with Low...
Homelite Mighty Lite Lawn Trimmer  Logo
968 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
