Question about Motorola Mobility I425T Cellular Phone
Carrier not supported - Motorola Mobility I425T Cellular Phone
I dnt get 3G on my blackberry 9700 bold
From Howard Forums Mobile Community, Tad Morose, 06-05-2011.Same question: Most likely the version of the phone you have does not support the 3G frequency of your carrier. The only thing you can do is trade it for a version that does support the 3G frequency of your carrier, e.g. from Rogers, Bell, Telus or AT&T. Could this be your problem?
Mar 08, 2015 | Blackberry Cell Phones
Can't connect to providers network
Hi Wayne
For this situations the best is contact the carrier directly and make a report of what is happening.
You can contact your carrier by following this link:
http://www.uscellular.com/support/index.html
Hope they can help you :)
Gaby
Motorola Support
Aug 05, 2014 | Motorola Mobility KRZR K1m Cellular Phone
SonyEricsson Vivaz how do you set it for 3g signal
rod please call your carrier service center and inform you your carrier support 3g network or not is your carrier support 3g signal then go to main menu and click phone setting and press network setting and select umts mow your mobile show 3g signal i hope it is helpful to you please vote me please
Jun 28, 2011 | Sony Ericsson Cell Phones
Where can i get a spare lower buckle for the shoulder straps for a Chicco Smart Support 69503 Framed Baby Carrier
Where can I order replacement parts for my Chicco products?
You may order replacement parts by contacting Customer Service at 1-877-424-4226
Sep 25, 2009 | Chicco Smart Support 69503 Framed Baby...
How to unlock gobi modem in panasonic f8
Hello !!
Good to hear, about you are using the Next Generation technology.
Gobi is the first multi-mode (CDMA/EV-DO and UMTS/HSPA) embedded wireless solution for mobile computers, giving users the ability to easily connect to major wireless carriers. Through the Panasonic® Carrier Selection Application (CSA) software platform, the need to physically switch out various single-module, carrier-specific modems to choose a different carrier has been eliminated. Gobi-enabled Toughbook® mobile computers can access AT&T, Sprint and Verizon Wireless wireless networks with one wireless device. Using the CSA, users are able to select the best carrier for any geographic area or switch carriers.
How to use of the Gobi:
By using Panasonic's Carrier Selection Application (CSA) users can select a wireless carrier. The CSA stores all major carrier connection managers on the hard drive of a Toughbook computer, therefore allowing users to access and select the required connection manager for each carrier at any time.
CSA software can be downloaded from the Toughbook Support site at panasonic.com/toughbook/support. After logging in, select "Downloads". The Panasonic CSA software can be found in the "Mobile Broadband (WWAN) Connection Software" section.
Here's a a link for Gobi FAQ's that would help you answering all the doubts that you have about 'Gobi'
https://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001&catalogId=13401&cm_mmc=PCSC_Toughbook-_-Vanityies-_-support-_-%20TCCHomePage
Check the link given above & it'll be helpful.
Thank You !!
Anurag Shukla
Sep 03, 2009 | Panasonic Computers & Internet
Cect i9 carriers
P168 is either 3band or 4Band. If 4Band, it supports all GSM network worldwide, but does not include 3G.
Either 3band and 4band supports T-Mobile and AT&T, Cingular
Feb 19, 2009 | Dual Electronics CECT P168 Cellular Phone
THERE IS A MESSAGE THAT SAYS ERROR 0502 EVERYTIME I TRY TO PRINT
This is copied out of Lexmark's KnowledgeBase, just so you know I'm not coming up with this off of the top of my head. Go to www.lexmark.com and click Support > Technical Support, and then search for ID: ENUS22800 if you would like to see the original, complete with pictures. Or, here's a text version:
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
The steps below will help you to identify and resolve each of these four issues.
1. Turn the printer off and disconnect the power cable from the back of the unit.
2. Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
3. Remove both of the cartridges.
4. Move the cartridge carrier over to the left-hand side of the printer using the carrier belt.
5. Gently clean the encoder strip with the cloth.
6. Move the cartridge carrier back to the right-hand side of the printer using the carrier belt.
7. Reconnect the power supply and turn the printer back on.
8. Perform the printer hardware test. Instructions on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
Did the printer pass the hardware test?
If yes, proceed to step 9.
If no, proceed to Reseating the encoder strip.
9. Power the printer back off and disconnect the power cable from the back of the unit.
10. Open the printer's front cover.
Move the cartridge carrier over to the middle of the printer using the carrier belt.
11. Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer.
12. Reconnect the power supply and turn the printer back on.
13. Perform the printer hardware test.
Reseating the encoder strip:
1. Turn off the printer and disconnect the power cable from the back of the unit.
3. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently pushthe encoder strip down and then back up to get it into the slot. Ifthe strip is completely out of the slot, it may be necessary to moveit first forwards and then back.
4. Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
5. Reconnect the power supply and turn the printer back on.
6. Perform the printer hardware test. Click here for instructions.
If yes, proceed to step 9 of Cleaning the encoder strip.
If no, proceed to the Black/Photo cartridge troubleshooting steps.
Black/Photo cartridge troubleshooting steps:
3. Remove the black/photo cartridge.
4. Move the cartridge carrier back to the left-hand side of the printer using the carrier belt.
6. Perform the printer test. Details on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
If yes, repeat steps 1-7 with a new black/photo cartridge.
If no, continue to Color cartridge troubleshooting steps.
Contact Lexmark if the problem persists with a new cartridge.
Color cartridge troubleshooting steps:
3. Remove the color cartridge.
6. Perform the printer hardware test. Instructions on how to do this are here:
If yes, repeat steps 1-7 with a new color cartridge.
If no, contact Lexmark.
Hope this helps!
Jan 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark all in one x5100 series begins to print then stops with"hardware error message 0502
Hope this helps!
Jan 21, 2009 | Office Equipment & Supplies
Fisher Price Deluxe Perfect Support Carrier
There are many companies that make baby carriers now. Fisher Price may have discontinued it, but I don't see a recall for it. I saw some on E-bay http://search.ebay.ca/fisher-price_Baby-Carriers-Slings_W0QQfclZ3QQsacatZ146535
Oct 28, 2007 | Fisher Price Deluxe Perfect Support Baby...
Motorola Mobility I425T Cellular Phone Logo
140 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
