Question about Garden
I have a troy bilt weedeater which came which the original speed bump type head for the line and a speedlock fixed line head, however there are no intsrtuctions for this attachment, is there a way to get the line in and stay?
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
Posted on Jun 10, 2009
  • 21 Answers
SOURCE: I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
Posted on Aug 22, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
Weedeater Head won't Turn?
I had the same problem with a Troy Bilt tb65ss. It sat in my garage for a year until I decided to tear it apart. I pulled of the head, removed the debris shield with a Phillips screwdriver, then removed the upper head assembly from the shaft. The inner flex cable is shaped like a square and had wiggled up the shaft until it was no longer engaging. I pulled it down and reassembled the upper head assembly with it engaged. It was a simple fix and took less than 10 minutes. It looks like a terrible design and a repeat problem. If it happens to me again I'll probably jb weld the flex cable in place. Good luck! You can always call the manufacturer and haggle over warranty and haul your trimmer all over town to an authorized dealer who will put it at the back of their pile because you didn't buy it from them or you can fix it in 10 minutes!
Sep 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Too Much String from my Troy Bilt
The majority of the time excessive string feed is caused by one or a combination of one or more of the following:
String wound backwards. Seems simple enough, but happens to the best of us.
Missing or improper spring.
Lubrication ANYWHERE on the shaft or inside the bump head assembly. This item should be clean and dry..but never lubricated.
If you know the model number on your particular trimmer, that would assist in troubleshooting.
I hope this helps.
DROPNDEAL
Jul 12, 2009 | Troy Bilt Tb70ss Gas Trimmer
The speedlock fixed line head cord won't hold
man i dont have a answer but if you receive a solution i would like to know also because i have the same problem
Jun 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Can not remove troy bilt weedeater head
Jim
Jun 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Can't get the head off troy-bilt weedeater to replace the line.
Threads are left hand. Hold the black wheel and use large plier or pipe wrench to turn the knob cloclwise
Apr 28, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
330 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
