Question about Maytag HAV2558 Top Load Washer
The inner tub moves slightly while the agitator is washing the load. Also, there is a grinding noise accompanying the inner tub movement that seems to be coming from under the machine. Thanks, RSR
  • 26 Answers
This is an indicator that the helical-drive/brake package assembly needs servicing.
At this point in the machine's life, it is best to have the transmission evaluated, snubber pads replaced, and the brake package competently serviced by a Maytag Tech.
This is a complete disassembly process wherein several special tools are required to disassemble and reassemble the machine.
Posted on Sep 08, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Wtw6300sw1 agitator moves clockwise no counterclockise mov
This sounds like the dogs need replaced in the agitator. It's relatively easy and inexpensive to do.
Feb 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
Wash machine vibrates moving several feet on fast spin cycle
If the suspension is still flexible, any unbalanced load will cause this. If it is accompanied by the tub striking the inside of the stationary tub, one of the suspension points may have failed.
I would remove the lower rear panel and watch the movement (with a good light) of the outer tub while a helper pushes the inner tub to its extremes to see if one of the points is 'unhinged.'
Jan 29, 2010 | Kenmore Washing Machines
Makes a grinding noise when on wash
HOW OLD IS THE UNIT ? IT COULD BE THE TRANSMISSION BEARINGS. IF UNIT IS MORE THAN 5YRS BUY A NEW MODEL
Aug 19, 2009 | Washing Machines
I replaced the coupler between gear box and moter and the cogs in the agitator now when spinning out the washer makes grinding noise
Murph!
Good job on the coupler and agitator cam! Way to go!
Now for the grinding noise... I assume that it wasn't making that noise before you worked on it, right? (except for the noise it makes when the coupler has failed. It make a kind of grinding noise, too.) So I'll assume that this is a different grinding noise.
2 things will cause this in "spin".
1.) Something is caught between the inner and outer tubs. Since you've had the cabinet off, you know that there is a perforated steel inner drum (the one with holes in it) and a plastic outer drum to contain the water. I've seen nails, paper clips, etc... get through the holes of the inner tub and get caught there. When the unit goes into spin, the object will spin along with the inner tub and rub the outer tub making a scraping/grinding noise.
To find out if this is the problem, remove the agitator again... yes the entire top and bottom portions of it. Now CAREFULLY inspect the inner tub and look for anything that may be stuck in the holes. It'll be small, so use a good flashlight.
2.) The "drive block" has cracked/broken and allowed the inner tub to drop to the point that it's grinding on the outer tub base. This one is a bit more intense than the fix above. If you would, please verify that there's nothing in the inner tub before we proceed to the next step.
Note----> I don't doubt that you can't handle the next repair. It's just that I want to eliminate the simple stuff before moving to the more complex stuff.
Let me know what you find, OK? Also... BEFORE you remove the agitator, look at the distance between the bottom of the agitator and the base of the inner tub. Use your finger for measurement. You should NOT be able to fit the tip of your finger between the two. If you can, write back 'cause then we'll be going into the drive block (#2) repair.
SG
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
Jan 28, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 110-91564100 Top Load Washer Problem
Sounds like my 91 Geo Merto LOL! Anywho when it washes the pump spins one way and water is basically thrown back into the tub, then when on spin it spins in the opposite direction and if there is a hose leak past the pump or the pump itself leaks it will come out of the drain system. As for the thump, check under the unit for anything that shouldnt be under there getting caught up in the mechanics. Let us know :-)
Sep 14, 2007 | Kenmore 23822 Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Open Questions:
See all Maytag HAV2558 Top Load Washer Questions
Maytag HAV2558 Top Load Washer Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
