Question about DCS PHFS Phoenix III Outdoor Patio Heater
Reflector damaged by hail - buy replacement? I have two of these heaters and both the aluminum reflectors were severely damaged by hail and need to be replaced. Where can I buy replacements?
Replace rear reflector on Holden Captiva.
Nearly all reflector replacements are done from inside the trunk/boot. Sometimes you have to remove the rear lining near the reflector to access, or, sometimes the screws or nuts are accessible through holes in the inner skin.
Nov 09, 2016 | Holden Cars & Trucks
Door reflector
The door panel may have to be partially or fully removed to access the retaining fasteners on the reflector.
Oct 03, 2013 | 2000 Oldsmobile Alero
How do you replace the reflector on a CT105T Glory scooter?
if its what I think it is .. there are pressed on washer.nuts that hold the reflector on that has plastic studs throught holes in the mount(or it may be epoxied in place with glue or some sort of adhesive..check with the dealer first for a replacement.. or a motorcycle shop that has the closest replacement type..good luck..
Aug 30, 2013 | Kuryakyn Reflector Covers-Large...
How to replace backlight on a ibm thinkpad t23
The backlight fault could be caused by a faulty inverter that supplies high voltage to the CCFL lamp OR the CCFL lamp could be faulty.
The inverter is located at the bottom of the LCD screen between the laptop's hinges behind the plastic bezel surrounding the screen,
The CCFL lamp is located on the bottom edge of the LCD screen behind a reflector that runs along the bottom edge of the LCD screen. The reflector is taped to the bottom edge of the screen.
To get access to the inverter, remove the plastic bezel.
To get access to the CCFL lamp, remove the screws that secures the hinges to the base, disconnect the video cable and inverter power leads from the motherboard.
Remove the plastic bezel, it may have double sided tape securing it to the LCD screen, BE CAREFUL you do not damage the glass on the LCD screen.
Remove the screws that fix the LCD to the lid.
Now you can get access to the reflector and CCFL lamp. Carefuly remove the tape as you will need it to fix the reflector back onto the LCD.
May 10, 2012 | IBM ThinkPad T23 Notebook
How do i chance the fog light bulb on my ford windstar 2003. I removed the sealed deam from it's location but the bulb is stuck inside. Do the sealed beam could be open???? tks
Are you sure it is a "sealed beam" light. If so, you can't replace the element in a true sealed beam. Thus the name "sealed". Most all recent cars have halogen bulbs that are mounted in a bayonet holder that comes out of the light reflector and lenses assembly. You turn the bulb holder about a 1/4 turn, usually counterclockwise and the holder comes out with the bulb. The bulb can be several different type mounts. Some plug in and some are bayonet mounts also. Get a new bulb and that will help you see how it mounts. When installing one of these halogen bulbs, DO NOT touch the glass bulb with you bear fingers. The oil from your skin will burn on to the glass and reduce the light and shorten the bulb life. Sometimes a little silicone grease on the bulb holder mount tabs will make putting it back together and taking it apart the next time. Just little grease, and only on the mount. Don't get anything inside on the reflector or the bulb and be sure you turn the mount all the way to seal out water. Anything on the reflector will damage the reflector surface. Maybe that is too much about a bulb, but it is important if you don't already know it. Good luck.
Thanks for using FixYa.
Gaker
Jul 29, 2011 | 2003 Ford Windstar
Model# 100501103 I need a new manual with assembley instructions. I purchasted the telescope several years ago. I now want to give it to my grandchildren but I can't find the instruction manual.
Sorry ut you will not find a manual for that small telescope. It's a reflector style telescope probably on an equatorial mount which must be polar aligned in order to be used.
Here is a Meade brand manual that is similar to your scope:
http://www.meade.com/manuals/TelescopeManuals/Reflectors/Meade4500.pdf
Dec 21, 2010 | Fieldvision 114mm Reflector (114 x 114mm)...
Replace rear turn signal bulb on 1996 cadilac
Hello; To change bulbs remove the cover in the trunk (pull it away) Remove the nut's/wing nuts and the assembly will come out. If you ever have to change any of bulbs that are on the deck lid you will need to remove the covering on the inside of the deck lid, remove the assembly and change the bulb.
Sep 17, 2010 | 1996 Cadillac Seville CA Value
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
I have a replacement chute reflector; need to remove retainer?
Sorry your ???? is not clear enough. A local mower shop could tell you much quicker with the visual we need and of course we do not have. They can either do or tell you if your inclined to do so.
Please rate. Thanks jj505
Mar 28, 2009 | Mtd 22" Yard Machine Push Mower
Heating & Cooling Logo
71 people viewed this question
Top DCS Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a DCS Heating and Cooling Expert? Answer questions, earn points and help others
