Question about Sony MDS-E12 Mini Disc Player
MDS E12 displays 'Over' and ejects all discs with 'Read Error'
Hi, hope someone can help as I my unit is rendered useless . I was skipping through some song compilation discs and on the 3rd one I was to tr.15. I turned the knob again checking for more tracks and it still displayed 15, being the last track. I ejected the disc, and noticed the red 'over' still displayed in the lower right, - which normally isn't there when there's no disc inserted.Not concerned I continued to my next untitled disc. It displayed 'TOC' , for awhile, then ejected the disc displaying ' Read Error'. I reinserted about 10 different discs, unplugged & restarted unit , still the same results, always the red 'over' displayed. I suspect the constant 'over' signal is the culprit - a 'memory function glitch' keeping it stuck in 'over' mode, (perhaps created when I turned the track knob after last tr.?). Is there a way, (a sequence of commands), to reverse/undo whatever is not allowing it to read discs ? Thanks Kermit
HW_Dude
  • 87 Answers
SOURCE: Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Posted on Mar 18, 2009
SOURCE: MDS-JE470 mini-disc capstan motor will not rotate disc and ejects
I have not had your problem myself, however, I am pretty sure the disc/s you are trying to play are not in the same readable format your MD player is, hence, the ejecting. I think you might have to either connect your player to a computer and re-initialise the system format/s and/or you may just have to (annoyingly) replace all of the MiniDiscs you have - which is not the best/rewarding way to go... quite irritating actually !!
Good luck to you though !!
Posted on Mar 25, 2009
SOURCE: MDS-JE480 MiniDisc Deck
The problem with the TOC reading and then appearing C13 is a problem with bad electrical contacts.
Remove the connection to the mains outlet, remove the top cover (5screws) and the remove the 2 paper flatcables that connect the main PCB and the disk unit on both sides. Plug them back in and possible your problem is solved.
A better solution is, of coarse, to replace both cables by new ones, as the quality is rather bad, and once disconnected, they should be replaced.
Good luck!!!
1000 soluciones
Posted on Jun 22, 2009
Obertelli
  • 3006 Answers
SOURCE: Sony MDS-JE480...Inserting disc..C13 error READ
The c13 error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your MDS-JE480, but I hope that my reply has given you a practical alternative means of solving your problem.
Posted on Oct 07, 2010
  • 4234 Answers
SOURCE: MDS JE520 Disc stuck in unit
the C13 is a mechanism error. The TOC means Table of Contents which is the part of the disk that determines the beginning of each track. These units are somewhat delicate and not really DIY repair candidates. Parts are still available for these. Look for either an authorized Sony service center or at least a shop that has worked on these in the past for repair assistance. The loading mechanism may need to be repaired or replaced.
Dan
Posted on Feb 03, 2011
Sony je500 takes in m/d then rejects after a few seconds ,,,help...
Either the mechanism is not loading correctly or the laser cannot read the disc
Jul 13, 2014 | Sony MDS-JE480 Mini Disc Player
MDS-E10 failed to record
If you recorded a disc and then the deck saved it; then you cannot play it is probably a bad mechanism. When I buy old decks I check them by inserting and recording a disc then ejecting it. If it will then not play when reloaded the deck is bad. Often the decks say they are saving but are damaged and cannot so this is the only way to know for certain.
Jan 27, 2014 | Sony MDS-E12 Mini Disc Player
Sony MDS-JE480...Inserting disc..C13 error READ CODE, keeps ejecting disc so dont know what to do pls help
Sep 02, 2010 | Sony MDS-JE480 Mini Disc Player
RTs00c00e00 ERROR MESSAGE, WILL NOT PLAY TURN OFF OR EJECT. TRIED TURNING POWER OFF AND UNPLUGGING, SAME ERROR MESSAGE COMES UP. PLEASE HELP! NOT IN MANUAL.
I just turned on my Sony MDS-JE520 and got the same error message RTs00c00e00. Didn't wanted to play MD, but did throw out the MD. After turning it on and off still got the same message. When I took the remote and pressed the key display, it came back to the normal "mode". Everything works again, so hopefully it stays with only this one-time incident.
Hope it will help you guys also.
Regards, Danny
Nov 23, 2009 | Sony MDS-JE330 Mini Disc Player
Disc error displaying on je500 and read error c13 on je330 model
The error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
Sorry there's probably no hope for your players, but I hope that my reply has given you a practical alternative means of solving your problem.
May 17, 2009 | Sony MDS-JE480 Mini Disc Player
I have two rack mountable minidisc players can any one in the world fix these things(frustrated).An MDS-E 12 & an MDS -E 10.One just fell over backward from the ground in a wooden rack. The other electric...
I have repaired a number of these over the years, the main problem is usually the loading mechanism or the optics. Neither is cheap. Where are you located?
Dan
Jan 23, 2009 | Sony MDS-E12 Mini Disc Player
MDS-E10 Problems loading and ejecting discs
Hi, its probably way too late to give this solution but there is a ribbon cable that runs from the main board onto the display board that causes this problem. Its very accessable from the top and all you have to do is pull it out clean the contacts and re-seat it. This will resolve all sorts of communications issues with the display and buttons.
Oct 26, 2008 | Sony MDS-E10 Mini Disc Player
Cd is stuck
put the same disk in , play it for a while then eject it properly.
Nov 13, 2007 | Pioneer AVH-P6500 Car Video Player
Sony MDS-E12 Mini Disc Player Logo
160 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
