Question about HP OfficeJet 6110 All-In-One InkJet Printer
Can't use fix with Snow Leopard
The fix on this site worked for OS 10.5. Now that I've upgraded to 10.6, I've lost scanning functionality. Any ideas?
Netflix runs choppy after snow leopard upgrade
Run 'Software Update'
This will bring the OS up to 10.6.8
Keep running software update until the system is up to date.
May 06, 2014 | Apple 24" iMac Desktop
I HAVE AN APPLE POWERBOOK G4 I PURCHASE FROM EBAY IT IS CURRENTLY RUNNING MAC OS 9 ,HOW CAN I UPGRADE TO OSX 10 ?
Hi Bobby
You will need to get an OS X installation DVD. Try eBay.Don't go for anything lower than 10.4 (Tiger)10.5 (Leopard) and 10.6 (Snow Leopard) should run fine on this machine.Don't bother with 10.7 or 10.8
Jan 05, 2013 | Apple PowerBook G4 Mac Notebook
How do I upgrade to 10.5 or .6?
Firstly you will need to buy a copy of 10.6. This is available from Apple (see link below) or you could get a copy from eBay.
Mac OS 10 6 Snow Leopard
The following article will tell you what to do next:
An Easy Guide to Installing Basic Upgrades in OS Snow Leopard 10 6
May 29, 2012 | Apple Mac OS X 10.4
Hi, Went to the Mac store to upgrade to Snow Leopard and was told my OS was "way too Old to upgrade to Snow Leopard!" Sorry, I'm a numbskull when it comes to these things. Figured as long as...
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the 10.6 Box Set.
System Requirements to run Snow Leopard:
  • Mac computer with an Intel processor
  • 1GB of memory
  • 5GB of available disk space
  • DVD drive for installation
Snow Leopard Installation Instructions:
  1. Just insert the DVD in the optical drive.
  2. Restart your Mac while holding down the C key.
  3. You will be guided through the installation procedure and be prompted at one point to choose which install option you want.
  4. Once the Snow Leopard install is completed the Mac will restart itself.
  5. You will probably be asked to register with Apple upon restart.
  6. Enjoy Snow Leopard on your Mac!
Q: Can I upgrade directly from Mac OS X 10.4 (Tiger)?
A: Yes. Apple recommends purchasing the Mac Boxed Set for this purpose, which will also update iLife (it is unknown at the time of this writing whether older versions of iLife work with Snow Leopard) and iWork. Also note that while it has been said that the $29 upgrade will work with 10.4, it is not officially supported and may be in violation of the licensing terms.
Q: What happened to the different install options? Can't I do an Archive & Install?
A: Apple has revamped the familiar installation options for Mac OS X. You now have two choices, either a straight upgrade or a clean install. Supposedly if you choose to do a straight upgrade, what actually goes on behind the scenes is what was traditionally known as an Archive & Install.
Q: Is there anything I can do to better prepare myself for the upgrade?
A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in Onyx. And finally, it would be wise to get your applications up to date using a program like AppFresh.
Feb 16, 2011 | Apple Mac OS X
Lost the scan ability from my printer.
I have this problem most times that I upgrade OSX. I remove the printer in system preferences, download the latest drivers from HP and then re-install. It's working better than ever now with Snow Leopard.
Feb 16, 2010 | HP Photosmart 3310 Printer
I have upgrades to Snow Leopard on my iMac and cannot access the printer commands to cheque the printer heads, and ink levels.
You can find useful information on site? http://www.epson.com/cgi-bin/Store/support/SupportSnowLeopard.jsp Mac OS X Snow Leopard Support Contact Support rightmenudottedline.gif snow_leopard_logo_sm2.jpg Welcome to Mac OS X Snow Leopard v10.6 support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Mac OS X Snow Leopard v10.6.
Check your Epson product CD to see if it already contains Macintosh OS X 10.6 drivers. If the CD indicates support for Macintosh OS X 10.6, follow the instructions that came with your Epson product to install your drivers and other software.
If your Epson CD does not indicate support for OS X 10.6, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR SNOW LEOPARD COMPUTER. Follow the step-by-step instructions below to obtain the latest software and utilities for your Epson product as they may be needed for this new operating system.
Good Luck.
Nov 03, 2009 | Epson Stylus Color 777 InkJet Printer
HP C4580 scan and Snow Leopard
Heads up..
HP Scanner software (ex. HP device manager, HP Scan Pro) no longer works in Snow Leopard OS since it's already preloaded. There are three methods for you to scan.
1. Preview
2.Image Capture
2.Scan under Print and Fax
Sep 20, 2009 | HP Photosmart C4580 All-in-One InkJet...
Snow Leopard has killed Scan Function on the HP Photosmart C4580 I have uninstalled, reinstalled... and quite simply wasted more than enough time... the Apple site support indicates unimstall and...
As you are not the first with this problem it would appear that all scan functions with HP and Snow Leopard are inompatible and not just on this model.
Sep 18, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
165 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
