Question about Canon Rebel XT / EOS 350D Digital Camera
Problem with canon
Of course, I have the Rebel XT. When I close the memory card door or replace the battery and close the door, the red light doesn't come on. After a few seconds, the power comes on and I get a CF error. I have replaced the card and battery.
  • 2 more comments
  • amae Jan 22, 2008
    Getting a CF error. HAve a freshly charged battery, tried a new card...HELP
  • stephmorier Jul 23, 2008
    exact same, looks like a slightly bent pin and maybe one missing? Is that possible?
  • rlsunsfan Dec 31, 2008
    when putting in a CF  card all of a sudden it say  error CF- I have tried all of my cards and they now all say the same error- what do I do?
  • amae May 11, 2010
    You are right...one of the pins are clearly bent. Does anyone know how expensive that is to repair?
You can ship your camera to Canon and have the in camera card reader replaced,it costs $300
Posted on Oct 19, 2008
How costly is that to repair? mine is broken aswell :( id like to fix it myself but the casing is hard to get off
Posted on May 19, 2008
Check the CF connector in the camera. One of the pins might be bent...
Posted on Jan 28, 2008
I have a digital Canon Rebel XT. My camera was operating fine until I put an old memory card in. The view finder started flashing "CF error". I immediately removed the "old memory...
Try removing the battery and the memory card. After about a minute return them both back and try to turn it on again. Update me what will happen.
Sep 15, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Err CF I have a Canon Rebel XT, how do i fix this error and what does it mean?
CF stands for compact flash which means you have an error with your memory card. Try removing and replacing your compact flash memory card. If that doesn't work you may need to format your memory card or replace it.
Jul 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
No power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Dec 04, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Camera will not turn on
Try changing batteries is the first thing you should try, the memory card isn't really important if your Eos isn't working.
If your Eos works, try looking on the lcd screen. It should give you an error code. Go to canon's website into the camera section and look up the code.
If that doesn't fix the problem, if you are still under warranty, I would suggest you to contact Canon for fixing it. If your under warranty, it should be free. If your not under it, you might need to pay.
Sep 08, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Where is the hold button on the Canon Rebel XT camera?
have you tried any of the following?
check battery installation
battery compartment not closed properly
cf card slot not closed properly
Dec 11, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon digital rebel 350D
The first thing to check is that the card door and battery door are firmly closed - press on them while the camera is on to see if it powers up. If not, there's probably a blown fuse - it will have to go to the shop.
Oct 08, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Internal memory
To LanaJones123
I'm afraid the Canon Rebel does NOT have an internal memory for storing pictures. Any pictures taken without a card installed will be lost.
FlashyBits
Sep 07, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Canon Rebel won't turn on, red light next to "CF"
Assuming you have tried another card you know to be good...
Remove the memory card, main and backup battery, switch the camera on for 10 mins. While you are waiting look into the memory card slot with a torch and make sure none of the pins at the bottom are bent.
If there is this will mean opening the camera to straighten it or sending it in for repair.
If not refit backup battery and main battery and cross fingers..:)
best of luck
May 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
249 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
