Question about Samsung J700 Cellular Phone
When a turn my phone and i try to do something it says low battery and i already charged it ,and i just got the phone like one week ago
I bought an i465 BoostMobile phone three weeks ago. About one week ago, I attempted to charge it and got a blank screen in return. For a while, the phone would not even turn on unless plugged in, though...
I suggest that you go to the nearest Boostmobile store to have your phone checked. Here's a link to locate the nearest Boost store within your area:
http://boostmobile.nearestoutlet.com/cgi-bin/search.pl
FYI, Boostmobile is an affiliate of Sprint so maybe a Sprint store might be an alternative if no Boostmobile store is nearby.
Here are some troubleshooting steps you might want to try:
Take the battery out for about 30 seconds and try to turn on the phone.When the phone goes to the white screen, just press the OK button (the circle button in the middle of the directional buttons) for more than like 3 seconds and you'll see the Motorola logo (do nothing) and then the phone will power ON by itself...it's very much like turning the phone off but without having to press the power on/off button.
If this doesn't work, then you really need to go to their store for help.
Mar 27, 2011 | Motorola Cell Phones
My nokia 6300 can't turn on.. i dropped it awhile ago, when i checked, it was still okay,,, but when i ran out of battery and tried to charge it, it wont turn on anymore,,, but the blue light around it...
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
S
Apr 06, 2017 | Nokia 6300 Cellular Phone
Verizon samsung sch u340 not charging:please help!!!!
the best thing i think you should do is buy another charger....
thats my first sugestion...
Jan 02, 2009 | Samsung SCH-u340 Cellular Phone
Wont charge/hold a charge
That definitely is a battery issue. The battery is either Low Soc or it is a failed battery. Most batteries on PDA's usually fail within a year because of the immense amount of use the phone has and the majority of the time the batteries are smaller in a PDA. Take your battery to a service center if one is in your area or call your carrier and inquire about the warranty on batteries (usually 1-year).
Dec 26, 2008 | T-Mobile Dash Smartphone
Car will not jump start
Check battery voltage. If volts are very low, put on charger. In many cases, you can't jump through a really dead battery... not enough voltage gets through to computer etc to make systems operate.
Battery may be used up... if it will not take a charge, replace it and check charging system before driving. PS: use a charger to charge battery. If it is very low, you candamage charging system in other vehicle. Also,,, You cleaned terminals already RIGHT???
Dec 16, 2008 | Mazda MX-6 Cars & Trucks
My nokia 6555 wont charge or turn on
I had the exact same problem. Just got a new NOKIA cell phone a week ago. Then i was sending & recieving text messages and it just died on me. Took the battery out, put it back in NOTHING. Recharged the battery, Still NOTHING. So I just kinda hit phone into the palm of my other hand a few times. And it turned on just fine. Im guessing something inside it jarred loose. Its worth a try....
May 17, 2008 | Cell Phones
LG KG800 charging problem.
if you already change the battery;' theres no problem with the battery; i think the problem is software try to reset the factory setting if dosen't work/ reinstall software
Feb 04, 2008 | Cell Phones
Battery Charging
If both the charger and the battery are warm to the touch, the battery is probably charged.
The low battery level warning level is learned by the phone. To train it, allow the battery to run down once until the phone stops working, then recharge it.
The best way totest the charging operation would be to try using the phone. Fully charged you should get about 6 hours of talk time from a fully charged battery, and at least a week of standby operation.
Dec 25, 2007 | Motorola Mobility V176 Cellular Phone
Samsung SGH-D807 problem
try taking the battery out and reinserting it.
Aug 25, 2007 | Samsung SGH-d807 Cellular Phone
Samsung J700 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
