Kodak ESP 5 Printer
Problem for Kodak ESP 5 Printer
I recently purchased a Kodak esp5 all in one. I
By sabra85 on Sep 05, 2009
I recently purchased a Kodak esp5 all in one. I cant get it to scan it says its scanning but its not doing anything help
Solution #1
posted on Nov 08, 2009
Not Rated)
melina5
Rank: Apprentice
Rating: 0%, 0 votes
I had this exact same problem. After weeks of frustration, and uninstalling, updating and reinstalling the software more times than I can count, I discovered the solution was to make sure the USB cable was connected directly to the computer, rather than through the USB hub I had been using. Once I plugged it into the back of the computer the scanner finally started working. Hope this helps!
Was this helpful?
Yes
No
Solution #2
posted on Oct 06, 2009
Not Rated)
annbwalton
Rank: Apprentice
Rating: 0%, 0 votes
Check which printer you have selected as the TWAIN source - there are several Kodak esp5 options - I found the one that works is: WIA-KODAK ESP 5 AiO
Was this helpful?
Yes
No
Solution #3
posted on Sep 27, 2009
Not Rated)
destinessoul
Rank: Wiz  Kodak Expert
Rating: 84%, 94 votes
Make sure that the printer is connected to your computer and you have the home center software installed on your system. Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Was this helpful?
Yes
No
Popular Solutions for Kodak ESP 5 Printer
Questions and Unsolved Problems for Kodak ESP 5 Printer
Do you recommend Kodak ESP 5 Printer?
Answer
Answer
Kodak esp5 has prominent black line on one side with every scan
Answer
cannot load software keeps freezing gets to 1 min to go then timer goes up to 16 mins then freezes... (More)
Answer
Kodak ESP 5 new cartridges color prints fine black will not print. Only have used Kodak replacement... (More)
Answer
The roller picks up 2 or more paper and is to thick to make it past metal tabs above roller in front... (More)
Answer
i recently replaced the ink cartridges and it is not printer as well as before
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kodak ESP 5 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
