Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I have a 9p5511c the picture is blurry before that the tv would make a snapping sound the picture would fade out for a second then fade back in but never lost the sound
  • kcarr25 Oct 19, 2009
    I wish to fix this myself how would i go about it? When i fix the high voltage leak do you think i will have to replace the picture tube also or should i do one repair at a time?
  • 178 Answers
You have a high voltage leak, one of the three crt's are arching to the metal chassis, this will cause momentary high voltage loss so your picture will fade until the voltage builds back up again.
Repairing this is hazardous because the voltage in the crt's are around 30,000 volts even with the tv unplugged. I don't suggest doing this yourself.
A technician will do the following he will attempt to stop the leak with specially formulated silicone compounds, If this fails the only alternative is to replace the picture tube that is defective.
The cost of repair depends on if the tube will have to be replaced, the initial repair using silicone should not run more than the standard service call rate for the company servicing the unit. If it is picture tube the cost could be upwards of $400.00
Posted on Sep 05, 2009
  • zapdbf Sep 05, 2009
    I also should add that if the problem is not taken care of it will eventually cause other problems and make the repair even more expensive.
  • zapdbf Oct 20, 2009
    The Picture tube hv lead is the one arcing, First you need
    to find where it is arcing take the front bezel off of the tv and remove the
    door behind the bezel. With the lights dim or dark, watch for the spark you
    will see a blue flash, you may need to lay on your back on the ground and look
    for the arch. Once you see where it is coming from clean that area with a dry
    cloth to remove dust and dirt from that area, (first unplug the set before
    trying this) then take silicone sealant and apply a thick coat to the area,
    where it is arching. let it dry completely before you turn it on again, read
    the instructions on the tube for drying time and wait for it to completely dry
    before you try to turn it on again. If you don't do this it can arch right
    through the silicone and cause a carbon path for it to follow again. and you will
    never get it to seal correctly again.
    If this does not work then that tube will have to be replaced but none of these
    tubes are made anymore. But supply stores may still have them in stock.
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
PIP fuzzes out, then snaps back in
It is definitely a circuit problem tf
it could be the pip board and or
components on or around it.would
require technical knowledge to
repair
Nov 30, 2007 | Sony KP-57HW40 57" Rear Projection...
Blurry & Fuzzy Picture Sony Trinitron
Check the filter capacitor to the supply to video output card. You can locate this capacitor at the CRT base card to your Sony Trinitron. Replace this electrolytic capacitor.
Sep 28, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Total loss of picture
The snap/pop was your lamp exploding. Your users manual will give you the part# and instructions on installing it yourself.
Apr 20, 2010 | Akai PT50DL24 Television
Phillips Projection TV - Model 9P5511C
Common problem with the model. Check the site www.TvRepairKits.com. They have a fix for the shrinking and expanding screen problem.
Sep 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Toshiba 50H71 Projection TV
I would check the power supply and the tuner section. This sounds like the low voltage powers supply is going bad or that the tuner section might be going bad. Does the picture fade to snow? Also I would suggest that you let a TV Technician take a look at the TV to determine what is happening. Most likely it is the power supply.
Thank you,
I hope this helps,
Shuttle83
May 27, 2008 | Toshiba Televison & Video
Picture clear then fades to snow when it does, makes annoying sound
sounds like poor solder on the ground conections of the tuner, depending on the age of the TV frostman
Feb 11, 2008 | Sony KV-27FS13 27" TV
I would guess to say the tuner for the pip is bad.
Nov 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Focus
The writing is more blurry than the picture. it is not that serious while shifting 1 focus wire might be loose. 2 crt base loose. 3 dust like thing near focus wire. 4 adjust focus control fitted on eht. caution it is high voltage portion do not touch unless you know about it.call tech to do it. good luck.
Sep 23, 2007 | Curtis CM19102 19" TV
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
