Question about RIM BlackBerry 8700c Cellular Phone
How do i set my blackberry phone up - RIM BlackBerry 8700c Cellular Phone
I have an old bb storm unlocked from Vodafone and im having trouble viewing videos i have recorded from the phone
You need to upgrade your blackberry software, since even your blackberry unlocked that software configuration still using default setting from your old network provider. Some phones have other problem after unlocked like browser stuck, death microphone etc. In this case your blackberry curve 8330 unlock code for verizon is working but you need some a little job to fix up your software. Like i said before that is a general trouble that may happened when we put blackberry unlock code at the wrong sequence.
Jul 05, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Also have a blackberry phone.Problem I do not know how to set up my GPRS settings and all other settings like,downloading,Email,etc. The camera also wont take pictures when I try to. PLEASE HELP...
To be able to use WAP, Internet browsing, MMS, Email you need to subscribe for BlackBerry data plan for your phone. BlackBerry is not like other phone that can work with the above mentioned features only if the GPRS setting can be put in place. BlackBerry device work with a special APN called blackberry.net which need to be assigned by your carrier (done by provisioning) in your SIM card. Except that there is no other way of using BlackBerry for above mentioned features.....
Jun 09, 2010 | RIM BlackBerry ® 8830 Cellular Phone
What is my password on my blackberry curve
Passwords to blackberry's are user set. this means somewhere along the line you or someone with your phone set your password. if you eneter it incorrectly 10 times the phone will reset back to factory settings
Feb 21, 2010 | RIM BlackBerry Bold 9700 Smartphone
App.error523 what dose that mean and how do i fix it
To resolve this issue, complete the following steps:
  1. Upgrade to the latest version of BlackBerry Desktop Software.
  2. Remove any recently installed applications on the BlackBerry device, then install the latest version of BlackBerry Device Software on the BlackBerry device. For more information about how to upgrade BlackBerry Device Software, see KB03901.
Nov 27, 2009 | RIM BlackBerry 8100c Cellular Phone
BlackBerry Storm 9530 Network Blocked
My BlackBerry 9530 network is block.and MEP check failed. How can i do pls pls help me
Sep 17, 2009 | Cell Phones
Describe your AT&T BlackBerry Curve
BlackBerry smartphones support individual security passwords between four and 14 characters in length. The use of the password is designed to make sure that only the BlackBerry smartphone user can access the information stored on the BlackBerry smartphone.
The BlackBerry smartphone rejects less secure passwords, such as those composed of identical characters or those that consist of natural sequences (for example, 1234). In instances such as these, the BlackBerry smartphone will display the message The password cannot be a sequence.
Set a BlackBerry smartphone password
  1. From the Home screen of the BlackBerry smartphone, click Options.
  2. Click Security Options.
  3. Click General Settings. Note: If you are running BlackBerry® Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Change the Password field to Enabled.
  5. Display the menu and click Save.
  6. Type your new password and click Enter.
  7. Verify your new password by typing it again and click Enter.
Change the BlackBerry smartphone password
  3. Click General Settings. Note: If you are running BlackBerry Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Display the menu and click Change Password.
  5. Type your existing password and click Enter.
Turn on password protection using the Security Timeout feature Security Timeout is a feature that, after a predetermined amount of inactivity, will lock the BlackBerry smartphone automatically.
To turn on Security Timeout, complete the following steps:
  4. Set the Security Timeout field to the amount of inactive time the BlackBerry smartphone is permitted before it is locked automatically.
Note: Clicking Lock on the Home screen instantly locks the BlackBerry smartphone.
Unlock the BlackBerry smartphone
  1. Press any key on the BlackBerry smartphone to display the Enter Password screen.
  2. Type your BlackBerry smartphone password. Press Enter.
Important: If a password in incorrectly typed ten consecutive times, all of the information on the BlackBerry smartphone is automatically deleted. This is a security feature.
Additional Information When the Security Timeout feature is set for a longer duration than the Backlight Timeout feature, the BlackBerry smartphone will lock automatically when the combined duration of the features has elapsed. For example, if the Backlight Timeout feature is set to dim after two minutes and the Security Timeout feature is set for 20 minutes, the BlackBerry smartphone will not automatically lock until 22 minutes has elapsed.
Sep 10, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Send me automatic settings for gprs services in my blackberry 8110. i cant able to set or change the settings manually . i.e. i am unable to change the ip address etc. my no. 9934489738
We suggest you to contact the service provider for the GPRS settings.
Before contacting the service provider for the GPRS settings ensure that BlackBerry services are active.
BlackBerry smartphones does not have any options to set GPRS settings mannually.
Aug 30, 2009 | RIM BlackBerry 8100c Cellular Phone
How do i reset blackberry curve 8330 to factory settings
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Dec 28, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry connect
I think its your service provider that has to send you the settings for that feature, go check it out.
Feb 19, 2008 | Sony Ericsson P1i
RIM BlackBerry 8700c Cellular Phone Logo
27 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
