Question about Maytag Atlantis MDE7400AY Electric Dryer
We have a Maytag Atlantis dryer. Inside the tub
We have a Maytag Atlantis dryer. Inside the tub are three attachments that run the length of the tub. One of those attachments has broken loose on one end and is now rattling when the tub is in motion. How do we reattach?
  • Keith Foutz Sep 05, 2009
    I think they are called fins and there are three of them that basically run the length of the tub. One end of one of the "fins" has come loose and is now moving, rattling and scratching the tub. I think they are secured on by screws but don't see them or how to get to them.
  • roberta3fan May 11, 2010
    Are you talking about the paddles that turn the clothes over? If so Im pretty sure there're made into the tub.
  • 574 Answers
Did you try opening up the back of dryer or the top?
Posted on Sep 05, 2009
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Timer not working does not stop automatically
Hello, This is going to be a problem with either the moisture sensor which is the metal strips inside the back rear of the tub or the running thermostat which is normally located on the exhaust vent right near the blower. Try cleaning the moisture sensor first. To test this problem set the dryer for a timed dry for 30 minutes. If the dryer stops the above is your problem. If you have any other questions please feel free to comment again. Good Luck!! Mike
Oct 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The paddle broke off in my Maytag Atlantis Dryer
you need to remove the frt cover 1st and then the screws will be accessible to remove top cover
Sep 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis Gas Dryer makes a loud noise when it is running. It works fine except for the noise. I have had the dryer about 5 yrs and this noise just started several days ago.
is it a high pitch noise. Like a noise that sounds similar to a old freddy cruger movie when the little girl on the tricycle passing by. If it sounds like that, then maybe you idler pully needs to be oiled..the idler pully is what keeps tension on the belt and lets the belt rotate smoothly. just like a pully. That maybe needs to be oiled..try doing that and see that works.
Jul 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Inside of my maytag atlantis electric dryer...top layer is erodin
I WOULD NOT WORRY ABOUT THE FINISH COMING OF EXPOSING ANYTHING TOXIC. WHAT COULD HAPPEN IS THAT WITH TIME, THE DRUM MAY RUST AND TRANSFER IT ONTO THE CLOTHES. DEPENDING ON ITS CONDITION, IT SEEMS NEW ENOUGH TO WARRANT INSTALLING A NEW DRUM. I DONT KNOW IF A COATING OF PORCALINE SPRAY PAINT WOULD STAND UP TO THE CONDITIONS IN THE DRYER BUT IT MAY BE WORTH A SHOT AS I DONT KNOW OFF HAND WHAT A DRUM SELLS FOR.
Jan 23, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
While my dryer is running it makes intermittent squeaks.
most of the time your rollers and belt are fine 1st thing to check would be the idler pully which keeps the tension on the belt so the tub spins
Dec 19, 2008 | Maytag MDE7600AY Electric Dryer
Dryer squeaks
THE BEARING ON YOUR TUB IS GOING OUT AND NEEDS REPLACING
Oct 14, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
249 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
