Samsung SyncMaster 710N 17" LCD Monitor Logo
Posted on Sep 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Half of the screen is black - Samsung SynchMaster 710N
My Samsung monitor cme out of hibernation with half the screen black (the bottom half) and its been the same ever since. Anyone got the same problem and is there a fix?
Anonymous
Level 1:
Scholar:
  • Contributor 36 Answers
  • Posted on Oct 27, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
36
Questions
0
Helped
62404
Points
57
Hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Samsung Master 1,449 Answers
  • Posted on Sep 07, 2009
Samsung Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614482
Points
3628
It is problem horizontal position problem from system ic
primary step you set horizontal position program key
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
How do i fix the bottom half of my laptop screen which is all black
It is unfortunate that the bottom half of the laptop screen is black. You may try performing an LCD BIST using the below link:
http://dell.to/1irqbYp
Also try connecting an external known good monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Synchmaster 2333 no red color
Rush to claim your warranty, the only thing you should do first is make sure that the input signal is OK: Hook up any laptop to any other monitor, then immediately (i.e. without changing what the computer is showing) hook it up to your monitor.
Another option is that you have a faulty cable. If it is part of the monitor, the warranty will cover it. If it can be detached from the monitor, borrow another cable to see whether that is the faulty piece.
Display half of screen
screen back light on the other side is busted which need replacement.
Samsung external monitor turns on briefly then goes black
Most likely it is a fault with the external monitor, either an inverter circuit board or the CCFL lamp.
To confirm if the laptop video card is faulty, connect another external monotor to the laptop and if the monitor is OK then it confirms the Samsung monitor is faulty.
1helpful
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
or just enter number in search field: 220409788372
thank you
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again,...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
