Question about Garden
Pull cord replacement
How can I replace the pull cord on a weedeater pe550 edger?
3 Suggested Answers
  • 246 Answers
SOURCE: I need a manual for a weedeater pe550 edger.
Hello:
You can Download Manuals After doing a Search Using your Units Model Numbers at this Site Addy; http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
or you can Contact Poulan/Weed Eater Using the Options at this Site Addy; http://www.poulanpro.com/poulanpro/contactUs.do .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
adrnlnrush19
  • 3 Answers
SOURCE: weedeater pe550 no spark at plug
Check the coil.
Posted on Sep 05, 2012
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
My PE550 weedeater edger that won't stay running. I have new carb, new fuel lines, new starter coil. any idea what could be the problem? I am now checking the gas cap, breather is good
check your fuel lines ensure you have them on correctly also check spark plug clean if necessary also when you change out fuel lines and carb it may take quite a few pulls to crank cause the little fuel system has to get primed up!
Aug 09, 2013 | Poulan Pe550 Gas Edger
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
The screws that hold the carburetor vibrated out and are lost. Any idea what size they are ? SAE or metric ?
Here is your part. To see your whole machine, just select Weedeater PE550 and a couple parts diagrams come up. The part number with a photo and the price are here as well. Shipping is stiff, but this is the best I can come up with. The head is TORX 20 it looks like (could be T-15), but the thread style is the important thing. Good luck!
http://www.ereplacementparts.com/carb-screw-p-269854.html
Sep 06, 2011 | Poulan Pe550 Gas Edger
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Replace pull cord
The pull cord works by wrapping around a coil that holds the line, and
this works by a spring, and there are 4 bearings in a clutch that help it to engage. Through wear and tear this can get to where it just doesn't work well anymore and needs cleaned. Remove the four screws that attach the motor to the clutch assembly. This will give access to the pull cord. Remove and be careful for the spring likes to shoot out when you remove the 4 tabs that hold the spool in. Replace the cord by running one end through the hole that the old cord is in. You then tie a tight knot in the line, you will see this when you remove the old cord. While there I would clean, lubricate, reinstall, the spring, and you should be back to trimming
Aug 06, 2009 | Poulan Pe550 Gas Edger
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Garden Logo
225 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
