Question about Sony KDF-E55A20 55 in. LCD Television
Lamp light in red
It binks red in lamp light
  • hockey08 Dec 08, 2007
    no...do i need a new lamp or no
    Genius:
  • 1,153 Answers
Is lamp door closed properly?
Posted on Dec 08, 2007
Mitsubishi wd-y65 binking red light problemm
Hello... Your TV has a lamp that has probably gone bad. The lamp is accessible from the back of the TV, located towards the right side. There is a square-ish piece of plastic with one screw on the left side. Unplug the TV, open the cover and there are two silver screws on the left, top and bottom. Loosen the screws, and then grab the handle and pull out the lamp. It may be obviously bad, but if you're not sure, take it to a service center to get their opinion. Be careful buying a lamp online, some will not last long and some may not work at all. Mitsubishi TVs need the correct lamp to work properly. I hope this helps.
Nov 11, 2017 | Mitsubishi Televison & Video
Fan in ventilation didn't work and power lamp steady red,lamp red and Temp lamp binking red
Very likely the airvent is block or the timer for the airvent cleaning is max. See manual how to clean air vent filter and reset the timer after cleaning it
Aug 08, 2010 | Mitsubishi LVP-X390 Multimedia Projector
I got a replacement lamp, but red light still binks and there is no picture. Why?
hello if the lamp cover is not mounted securely the self -diagnostic funcation works and the power/standby indicator flashes for 3 times .when you've corrected it the power/standby indicator goes out and the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
On my wireless network adapter for the xbox the light is red
The adapter is inoperable. You'll have to send it in to Microsoft for replacement or get a new one.
Sep 22, 2009 | Microsoft Wireless Network Adapter Xbox...
Binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
My Sony LCD Projection TV (KF-60XBBR800) will play for a minute or so, then go black for about 30 seconds while the STANDY light flashes continously. Someone told it it was probably a bad projection lamp...
Hi ,
Yes the lamp can be the problem, sonys do that, they kind of reboot.
the light goes out and the green light binks and sometimes it start up again eventually it doesn't and the green light blinks forvever.
I've been a TV tech for 30+ years and still work on these weekly
hope this help
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 18, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
RED LIGHT
press and hold the menu and device/input buttons both in together for 5 seconds then the led will blink a number of blinks pause then blink another number of blinks then repeat that process. Let me know thw binks you get for the two digit blink error code.
Feb 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Turns off by itself-Powerled blinks 5 times
the lamp driver is the power supply which supplies the lamp with electricity. with the rear cover removed it is located in the center. there are 4 screws holding it in place and you will see 2 thick red wires leading to the lamp.replaced this ( part # 1-468-875-11 ) and your tv will be ready for the super bowl
Jan 19, 2009 | Sony KDF-E55A20 55 in. LCD Television
My TV set do not come on. It only binks a blue and a red light and I hear a fan noise that comes on and off
It sounds like the lamp is blown. You need the lamp to give illumination. If you have the technical experience to fix it you will need to source a replacement locally.
Jan 18, 2009 | Televison & Video
Sony KDF-E55A20 55 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
