Question about Dell Latitude D600 Notebook
My Dell610 laptop says that it can not recognize
My Dell Latitude 610 laptop says that it can not recognize the AC adaptor (it is the correct Dell model 90 watts) and will therefore not charge the battery! Any quick fixes? I've looked in the Bios and it has the same message.
  • 558 Answers
You need a 90 watt power supply,the one you have is bad
Posted on Sep 05, 2009
I have a Dell latitude D 600 can i use a hard drive from a Dell latitude D 610
A hard drive will work almost anywhere as long as you have the correct connection or adapter. You also need to make sure BIOS recognizes it if internal.
Jan 26, 2013 | Computers & Internet
I have a dell latitude d800. I need an ac adaptor a battery pack
The Dell Latitude D800 series of Notebook PC's, uses an AC adapter that puts out 19.5 Volts DC. 90 Amps. (Amperes)
This is one example I found from a quick search,
http://www.acadapterz.com/product_26527.html
Regards,
joecoolvette
Jan 16, 2012 | Dell Computers & Internet
My latitude D530 laptop doesnt recognize the ac adapter anymore a screen tells me to reset the adapter, how do you do that. I been using this adapter and battery for awhile now it doesnt recognize it
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
If it's still under warranty contact Dell Support. If not, you'd better buy one replacement.
Try this link: http://www.chargerbuy.com/replacement-dell-latitude-d530-ac-adapter-65watt-19-5v-3-34a.html
Mar 09, 2011 | Dell Latitude D530 Laptop AC Power Adapter...
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
My dell latitude d420 board is not responding to power
if its not responding check power cables (ac adaptor/power cord) .if power cables are good board needs to be replaced. you must call dell to service the laptop.
Dec 30, 2010 | Dell Latitude D420 Notebook
Sir, I use" family 9"
If you are using an adaptor which is of high Watt and voltage that may fry up your motherbiard so be more careful while you are using adaptors with higher wattage and voltage
Dec 26, 2010 | Dell Latitude C640 Notebook
My Dell latitude will not re-boot
Did you check your battery LED light or Motherboard?
May be you need a dell latitude d610 battery?
This article can solve your ac adapter problem.
http://www.laptop-junction.com/toast/content/dell-ac-power-adapter-not-recognized
Nov 23, 2010 | Dell Latitude D610 Notebook
My Dell latitude d610 charging circuit not working on board
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Jul 31, 2009 | Dell Latitude D610 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
62 people viewed this question
Alun Cox
