Question about BBQ Guys BBQ400C/G42 Grill
My BBQ flame stays on low
I just refilled my propane tank plugged it in to my BBQ which is about 3 years old. I used it a couple of times since then and it worked fine. Then the last time I used it the flame would stay on low. Even when I have the knob turned on High. Does anyone know how to fix this problem? Thanks for your help.
  • 28 Answers
Most likely your regulator. Changing the Regulator
Posted on Jan 19, 2018
    Top Expert:
  • BBQ Guys Master
  • 20,242 Answers
I would check the gas tubes for spider webs
Posted on Jan 06, 2018
3 Suggested Answers
SOURCE: no gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Posted on Dec 22, 2008
  • 512 Answers
SOURCE: we received a natural gas connection bbq and don't
no all components of grill need to be converted to propane. cheaper to buy new grill. Call Manufacture and see if they sell conversion kit. Most companies don't do to liability matters,
Posted on Mar 29, 2010
Grill doesn't want to heat up.....When I turn the propane tank on I used to hear a little hiss which means bbq is ready to ignite but when I try to light it now there is no hiss and the flame is very...
The hiss is from the reg when the pressure equalizes on both sides of the diaphram with the pressure coming out of the breather hole . So check the reg .
Jul 10, 2017 | Char-Broil 463232103 Grill
Connecting Reddy HD30 to RV Propane Tank
pipe feed could be too small poor flow of gas or flamesafety is cutting in
May 26, 2010 | Reddy HD30 Heater
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
My Jenn air BBQ grill will not heat up all of
Couple things could be happening here. If you do exchanges, have you used more than one different propane tank since you've had this issue? This eliminates the possibility of a low tank pressure and a faulty tank connection. Next you need to look over the burners and the propane flow tubing. Spiders LOVE the sweet smell of propane and make their webbing inside the piping that get's the propane up to the burners. At your flow valves/On/Off knobs you'll notice that the propane shoots from the valves into a pipe with an air gap to gain oxygen. Look in there to see if there's any webs. Also should be a gap were that piping meets the burners, so you need to look there too. Depending on the age of the grill, you need to look the burners over. Corrosion & rust can cause the flame/propane holes in the burners themselves to cake up and close up causing much less flaming/heating opportunity. Also depending how much you've used it, it could be grease/dripping/sauce caked up over them too so they may need to be detailed/cleaned. It's not a pretty job, but grill maintenance that should be done every spring. When the burners get caked is when it's really fun and you need to remove them and clean out the holes with toothpicks. Jenn Air makes quality products, but being a BBQ and outdoors, it's just as vulnerable as any other to elemental and use issues. One last thing to check, some regulators (the disk shaped part right where the hose attaches to the tank) have another air mixture intake there with a screen on one side. Make sure there's no water in it and the opening is face down if you have one like that. Otherwise it's restricting the flow of the propane. I haven't seen one of these in a while, but they're still out there so check it too.
Jun 10, 2009 | Thane Q-BBQ Grill
No gas getting to bbq
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Gas BBQ - Won't light
hi Be sure the thermostat or heat dial is set properly. If the appliance has a pilot light, be sure it's working. make sure that you connected the pipeline correctly open the faucet of the tank try to fire it up ? working ? good... NO???? close everything(faucets,plugs...) your new tank that you connected is empty.... it happens.... have a good 1
Apr 06, 2006 | Barbeques Galore Turbo Classic 3-Burner...
BBQ Guys BBQ400C/G42 Grill Logo
265 people viewed this question
Top BBQ Guys Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a BBQ Guys Grilling Expert? Answer questions, earn points and help others
