Question about Canon PIXMA MP600 all-In-One InkJet Printer
Display reads that there is a paper jam
Have done everything but unable to correcrt the problem. No paper jam is found. When I turn it back on it feeds paper through just fine but then displays that there is a paper jam. I have a Canon MP600
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Mar 23, 2013 | Ricoh Aficio SP-C210SF Printer
Printer says paper jam and there isn't anything in it
Maybe there a problem in the paper loader of your printer. the gear that let the printer loader turn and detect the paper maybe damage. try to disassemble the printer and if you find part that broken maybe you can find replacement on that gear in the service center of that particular printer or model. if this not found in the inside try to examine also the circuit of the printer.
Jan 25, 2008 | HP OfficeJet 6210 All-In-One InkJet...
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
DCP-J125 Uable to print (36)
The message Unable to Print (followed by a two character code) will appear on the display for one of the following reasons:
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper, stuck in the machine
- Mechanical malfunction
The most common cause of the issue is dirt on the encoder strip. Clean the encoder strip by doing the following:
CLEAN THE ENCODER STRIP
NOTE: The images shown below are from the representative product. The customer's model may look different from the picture.
1. Locate a lint free cloth such as a T-shirt, DRY eye glass cleaner cloth, DRY monitor cloth or wash cloth.
DO NOT USE ANY TYPE OF PAPER PRODUCTS (EX: paper towel, tissue paper, napkin, filter, news paper etc.) This will help ensure the dirt is removed from the encoder strip.
CHECK FOR FOREIGN OBJECTS & PAPER JAMS
2. After thoroughly cleaning the encoder strip, look inside the machine and in the two corners for jammed paper or foreign objects and remove them if any are found. Pieces of paper may be jammed under the print head.
If the print head is locked to the right side of the machine, press and hold the STOP/EXIT key for 5 seconds. This will cause the print head to move automatically to the middle of the machine and allow you to look for debris in the right corner.
3. Leave the scanner OPEN and turn the machine around so you are looking at the back of the machine.
4. Open the Jam Clear Cover and look inside the machine for paper. Remove any jammed paper that appears; then close the Jam Clear Cover and turn the machine back around to the front.
5. Gently close the scanner cover and verify the error message cleared from the display.
If you cleaned the encoder strip ONCE and the message continues to appear on the display, clean the encoder strip again. It is common to clean the encoder strip multiple times to resolve the issue.
If you cleaned the encoder strip at least TWICE and the message continues to appear on the display, unplug the machine from the power outlet for 2 seconds and plug it back in to cycle the power.
TEST THE MACHINE
NOTE: After a paper jam has been cleared, the Brother machine may complete a 2 minute cleaning cycle to remove paper dust from the nozzles before printing.
May 01, 2012 | Brother Office Equipment & Supplies
ETB replaced now when printer is turned on no fans run and error message on display states paper jam in ouput bin. Looked found no paper jams.. HP CLJ 2605dn.
Double check EVERYTHING you disturbed when you replaced the Transfer Belt.
Probably 2 things not connected properly - fan obviously, and a sensor.
Jan 13, 2010 | HP LaserJet 2605DTN Color Printer
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Brother mfc 5460cn
take it back to the store
you do not need these headaches on something new
Jun 14, 2009 | Brother Multi-Function Center MFC-240C...
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Paper Jam 2
We had the same proplem - did you check there was no paper jammed when you opened the back cover?
Sep 09, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
41 people viewed this question
old marine
old marine
