Question about Philips 50PFP5332D 50 in. Plasma Television
Turned the 50" plasma on and screen is black and white, blurry, and their are 7 lines from top to bottom spaced out all the way across the screen. a friend and I previously Moved the TV 3 days ago to a new home. was very cairfull moving it, no bumps and moved the Tv in the back of my truck by it self. insuring no problems because I was very nervious moving it, note: drive was only a 14 mile drive. Tv sat for roughly 2 hours then I tured it on with no problems. It worked great all day and night. next night TV also worked great. I had it on for 10 minuts that night and turned it off 15 minuts later I turned it back on and imideatly the 7 lines appeared with black and white picture. the lines are the only color on the screen. I unpluged TV from wall, unpluged DVD player, and unpluged satolite for 15 hours. Pluged TV back into wall and problem still accures. any sujestions, please?
  • 2 more comments
  • mike tucker Sep 07, 2009
    How dose something like that get dameged? I'm very cofident on how cairfull i was moving the TV. What is the convergence chip, where is it located, and where do i get one? thanks for the feedback. One more thing I can think of is I layed it on its back on a thick rug, without thinking or asking anyone if it's ok ,of course. Is it ok to lay it on its back?
  • mike tucker Sep 08, 2009
    I layed the TV on its back for a 14 mile drive. TV wasen't turned on for days before moving. but turned on 20 minets after it was braught into the house and it worked for 3 days after moving it.
    theirs no red line. theirs just 7 colored lines running from top to bottom of the screen about 4 inch apart from each other and the screen is black and white. how do i download to the TV?
  • mike tucker Sep 26, 2009
    yes it was the convergence
  • 448 Answers
If the red line is visible across the screen then installing the Firmware update "EJ30U_0.81.8" should resolve the issue. You can download the mentioned Firmware update from the Philips Support site.
Posted on Sep 08, 2009
  • 1 more comment
  • Rahul Prashant Singh Sep 09, 2009
    Convergence chip in a TV is used to distribute colors equally on the TV screen. If the convergence chip gets damaged then the colors on the TV may not appear normal.
    You can check in the TV for any option to adjust convergence through settings. If there is no such settings in the TV then you can contact service center to get the convergence chip replaced.
  • Rahul Prashant Singh Sep 26, 2009
    You may contact service center to get the part # of the convergence chip or the convergence chip replaced.
  • 430 Answers
I am sure there's a problem with the convergence chip. It must have been damaged. Replacing will surely help.
Posted on Sep 05, 2009
  • Nandini Dhar
    Nandini Dhar Sep 07, 2009
    Not at all, because keeping things on back can cause insulation and internal burning of componenets.
  • Nandini Dhar
    If none helps, I suspect a faulty flat panel board.
Samsung tv PN50C550GIXA has blank/black space all across screen. It is about 4 inches wide. TV comes on and you can see top and about 7 inches of the bottom.
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are almost similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts/
Apr 20, 2018 | Samsung Televison & Video
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
I have a LG 50" 780P plasma tv. Approx 4 years old. Model- 50PQ30. The screen picture is cut in half the top half is normal but the bottom half is all distorted and has white horizontal lines going...
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Feb 18, 2018 | Televison & Video
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Philips 50PFP5332D 50 in. Plasma Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
