Question about Sport & Outdoor - Others
How do I know if my water pump is not working on my 15 hp two stroke year 1996
    Problem Solver:
  • 15 Answers
Are you talking about a boat motor? If so, you should see water pumping when it is running.
Posted on Sep 05, 2009
HOw do you install a water pressure valve on a 1998 70 hp Evinrude 4 stroke engine
I can't find anything on this. There is a water pump and a bypass valve, but not a 'water pressure valve'. The water in the coolant system is under very little pressure as it is pumped up from the lower unit, around the power head and then down to the exhaust outlet under water with some exiting the jet hole to show you it is working.
install water pressure valve on 1998 70 hp Evinrude Google Search
Mar 27, 2018 | HP Boating
I was running in a tank my new 5 HP honda 4 stroke and it quit pumping water...and the water is well above the cavitation plate.There was a stream coming out higher up when I started it.
Many manufacturers recommend removing the propeller to tank test small motors the small stream above is what is called a tell tale so you know the pump is working .
Aug 13, 2017 | Honda Boating
I have a 2003 yamaha 40 hp four stroke outboard, this year started up seemed to run great after about 25 minutes i shut it down an hour later checked oil crankcase full of water
water in the engine crank case oil --major seal or corrosion problem in the motor
water in the leg gear box --
pump seal on the drive shaft
Jun 01, 2017 | Yamaha Boating
I have a 1996 Mercury 15 hp 2 stroke, where is the water intake for cooling?
There will be an intake at the bottom of the leg
Nov 26, 2016 | Boating
Why is my yamaha 2003 4 stroke 40 hp seem to be seized only 400 hr ran fine last time 3 weeks ago
Water pumps fail sooner from non use than using them all the time.13 years is a rather old unit
Oct 19, 2016 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
1996 Evinrude 9.9hp, 2-stroke power loss.
Checked the vent cap on the fuel tank?
Check if it runs again great after pumping fuel...
Check when it drops power if both spark plugs still sparks...
You can have a bad coil or cdi...
Jul 25, 2017 | Boating
Water does not come out of the port hole all of the time.
you might just have dirt in the water view port try a real smal drill bit BY HAND to clean the hole . if the morot doesn't run hot then you really don't have a problem
Apr 27, 2010 | Boating
Sport & Outdoor - Others Logo
230 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
