Question about Canon Office Equipment & Supplies
Canon PC-745 stopped working.. paper jam light
My Canon PC-745 has stopped working. It will power up fine. But when I try to make a copy, every things turns on, but right before it takes paper from the tray, a paper jam light turns on.
    Guru:
  • 389 Answers
Sooner whole in трее there is what that subject , can broken part or scrap of the paper. Open and see attentively, in that place, where paper sticks. I for its work so much took out stranger a subject(
Posted on Sep 12, 2009
    Scholar:
  • 136 Answers
I seen this problem before, You need to call a Service technician And tell him you may have a Paper Feed Problwm so tires may be needed
Posted on Sep 13, 2009
  • copiersplusw
    copiersplusw Sep 13, 2009
    I believe this should resole your Jam issues
Envelopes jam, worked fine when I bought it 6mths ago
Hi Jerry
the paper tray has a triangular upright paper guide at the back edge (roughly in the centre) to keep the paper from sliding out the back of the tray. It has a serrated edge on the paper side. Try covering the edge with some masking (or similar) tape to make it smoother. Not sure about envelopes, but this has stopped copy paper jams, so worth a try. If it doesn't work for you...easy enough to remove the tape.
good luck!
Mar 07, 2015 | Canon Pixma MX922
My PC 745 comes up with an error code of a paper jam but I cannot find any jammed paper. Any suggestions.
completely remove the paper cassette and look for A SMALL PIECE OF PAPER stuck inside the machine in the paper path. Also use a flashlight to check for tiny bits of paper in the exit section of the machine where the fuser (hot) rollers are.
Dec 16, 2010 | Canon PC-940 Black and White Copier
I HAVE A CANON PC 745 COPY MACHINE AND IT WONT PRINT IT MAKES A FUNNY SOUND AND THERE IS NO PAPER JAM AS THE LIGHT INDICATES WHERE CAN I TAKE IT IN FOR REPAIR
i would try this first clean the pick wheels with contact cleaner to insure they are gripping the paper if this dont do it. uninstall the unit and reinstall
Oct 01, 2010 | Office Equipment & Supplies
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
Aug 19, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lines repeating on copied paper from Canon PC 745 copier.
You probably have a piece of paper wrapped on your pressure cleaning roller inside the fuser. The patterm on the paper is the same and the spacing is equal and it is in the direction or feed.
Apr 11, 2009 | Office Equipment & Supplies
Canon PC 745 error ''8'' plus zigzag. What does it mean?
try to see if there is any paper in the way out of maxine (fixing unit ) or on the right side of the machine you have paper jam thats the signal zigzag
Dec 27, 2008 | Office Equipment & Supplies
697 people viewed this question
old marine
old marine
