My panasonic laptop has 5 vertical lines across the screen. Each line is about an inch wide and is made up of many horizontal flickering lines. Can anyone help? Thanks!
Boot to safe mode that is you press F8 when the unit is starting and keep tapping it till you reach advanced startup menu. If you still have the lines then the display is bad. If it goes away then the drivers are wrong.
I accidentally adjusted the settings on my monitor and now when i start it i just get a black screen...
(More)
I accidentally adjusted the settings on my monitor and now when i start it i just get a black screen with flashing colors.
turn if on picture shows and immediately goes black. turn monitor off and then on again. picture...
(More)
turn if on picture shows and immediately goes black. turn monitor off and then on again. picture shows and goes black.
My computer boots up, I see the MPC screen whit it does a hardware check but when windows starts to...
(More)
My computer boots up, I see the MPC screen whit it does a hardware check but when windows starts to load the screen goes dark. You can see a mouse arrow for a second or two and then nothing -- but the computer still boots up fine and is accessible remotely (using LogMeIn to access it) and is fully functional, with no error messages.
powers up but the picture is so faint that you can not make anything out. what might be the problem....
(More)
powers up but the picture is so faint that you can not make anything out. what might be the problem. power supply is good.
