Question about Kenmore Refrigerators
Unable to put back ice compartment of kenmore side by side refrigerator model number 106.5812*800
    Problem Solver:
  • 11 Answers
If you angle the ice bucket down, a little too high for where you think it should be, it should slide in. It's got kind of a catch at the end of it so it doesn't fall out when it's full. Otherwise, honestly, best bet might be to check one out at a store.
Posted on Sep 05, 2009
Kenmore elite refrigerator
Leaking Refrigerators I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain lines. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more simple in clip below. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
What is your model number? Kenmore model numbers look like this example=> 321.12345678
Jun 06, 2013 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
I have a Kenmore Coldspot refrigerator with top freezer. The icemaker is "leaking" if it is the right word into the ice tray bin that it is building a chunk of ice along with the regular ice...
What that sounds like is the water valve isnt fully closing. This tipi wrote is about that issue,
http://www.fixya.com/support/r10343350-icemaker_drips_causing_all_ice_freeze
Reply with your exact model number as found on a label usually on the ceiling of the refrig. compartment and i will give you the part number for that water valve.
GENE
Sep 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting...
is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Sep 04, 2010 | Kenmore Refrigerators
I have Kenmore refregrator model 51272200. Water is leaking inside and forming ice at the bottom of the freezer. The refregrator compartment is warmer than usual. Your help on this is greately appreciated....
CK THE ICE MAKER WATER INLET TUBE IT MAY BE ICED AND CAUSING THE WATER TO RUN DOWN THE BACK / ALSO CK THE DRAIN IN BOTTOM OF FREEZER / A VERY COMMON PROBLEM . THIS WILL ICE THE BOTTOM OF FREEZER FLOOR AND RUN OUT ON FLOOR .. .. MM HOPE THIS HELPED ..
Jul 01, 2010 | Kenmore 53092 / 53094 Side by Side...
Ice maker will not dispense ice thur door after taking apart! I feel like something was not lined up properly,motor runs but auger not moving darrelledd@yahoo.com
Sears models use a different way of numbering their models. Look on the door frame and near floor with fresh food compartment door open and see a series of numbers like this 911.46569
I will be able to help you better if you can find that number, Thanks, Sea Breeze seabreezehvac@yahoo.com
Apr 20, 2009 | Kenmore 53082 / 53084 Side by Side...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Ice maker problem
Good Morning,the solinoid valves are crossed in the back of the refrigerator. shut the water off and switch the tubing around that comes off of the valves
Dec 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
