Question about Toro Garden
Toro 74701 rt wheel trans seems to not be working /very strange all else seems like new. nothing broken or missing
2 Suggested Answers
  • 4 Answers
SOURCE: Wheel came off. Can I replace just axel instead of hydro transaxle?
The hydro Transmisson Is not the easyest to repair. That is probably way they said that. plus the labor whould have been $350 to $500. So most shop won't repair them.
Find A break down on line so you can see what your getting into.
Posted on Aug 04, 2012
Why won't the wheels move forward or backward on my Toro 54" Zero Turn Lawnmower. Was mowing and it stopped moving.
usually if the pins are pulled out that is the freewheel position. push them in to drive. if the trans locks in drive and it is hard to push it should be ready to mow. unless the drive belt is stretched or broken or a linkage is out of adjustment or broken.
Jun 01, 2018 | Toro Garden
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Why does the Hand Wheel fall off?
Then hand wheel is secured to the machine in one of two ways. The first is there is a white disk, and if you pop it off there is a screw underneath.
Sounds, though, like yours is a force fit. That is, it is removed by squeezing it together and rocking it from side to side. It would go back on the same way. There is a YouTube video that demonstrates hand wheel removal and replacement for both types of hand wheel, and you can see which you have. Here's the link: https://www.youtube.com/watch?v=vIAfiy-xGsY&list=UUSicV9kXB2fmm3z_0FKSA_A&index=10
It could be that it's cracked, but it can be replaced if it is.
Jul 03, 2014 | Singer One Plus Computerized Sewing...
Toro briggs OHV runs too fast
throttle spring could be broken stretched or missing
Nov 14, 2012 | Toro Lawn Mower With Toro Power Tools
Aug 04, 2012 | Toro Garden
Toro 22" recycler Mod
Got the same problem with mine, replaced the drive belt, removed the wheels and checked for rocks and pebbles, greased, checked also bottom of gearbox. grease was present no broken teeth, top pulley has excive side to side play. Have not disaasembled yet. Hope someone would have had a solution here.
Apr 11, 2011 | Toro Lawn Mower With Toro Power Tools
My toro front wheel drive is not engaging when i pull the lever?the drive belt seems loose . does it always have some play in it.?
yes...tightening the belt happens when the handle is pulled...take the cover off the belt an see if there is play in the pulley on top of the transmission...if there is the trans is bad and must be replaced...
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Toro mower 20016 makes grinding noise and no longer goes forward.
sounds like ether the the wheel gears are stripped or you have a bad trans.Pick mower up a little and take the bolt out of the wheel. The wheel will come right off check the gear on the inside of the wheel to see if it is stripped or worn out if not then it is the trans which are pretty cheap go to toro.com and look it up
Aug 07, 2009 | Garden
Garden Logo
116 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
